Originally Posted by
Columbo
Thank you very much for your informative and very helpful response. Yes, I am just starting out and self teaching.
Perhaps I could ask you another question. I watched a short video on arc welding tips and the guy was using a clamp-like electrode holder that he called a "stinger". He said he welds with his finger on the "quick release" and if the rod sticks, he immediately releases the rod and then wiggles the rod back and forth to unstick it from the material. My question is, the rod holder with the PA200 is the kind that you insert the rod and twist to tighten. If the rod sticks, what would the procedure be with that type of electrode holder? Also, what are the consequences, if any, of a rod sticking?
I never release them, just wiggle back and forth quick or give a jerk to pop them free from the workpiece. You don't want to leave them stuck as it'll overload the circuit, but it's not instantaneous.
Check out weldingtipsandtricks.com you can look through them by process and metal and Jody is a great guy. Lots of info that everyone can understand, no degree required.
I'm not a fan of the style stinger that comes with the machines, Tractor Supply has some at a good price in the other style (as does Everlast) I'll be picking one up before long and changing mine over. Not that there's anything wrong, I've just always used the other style and like it a bit more.
Thanks again.
Trip Bauer
Former USN HT
Everlast 200DX New Model
Hobart Handler 125 MIG
Van Norman #12
Atlas 12" engine lathe
