Results 1 to 12 of 12
Thread: Looking for Special 12 VDC Circuit Breaker
    Default Looking for Special 12 VDC Circuit Breaker
    I am i need of a 12 Volt DC Circuit breaker ( 30-40 amps) that is an inline breaker that trips in a pull type application by weight 300-400 pounds. I have used some in the past that are flat hinged type but need one that is cylindrical about 2" in dia and 3-4" long. Have seen them in use years ago but do not remember the manufacture.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
    Is this actually a circuit breaker that trips according to an applied weight, rather than an electrical overcurrent? Or is it a specialized switch? I googled but didn't find or learn anything.
    Yes it trips by weight the hinged ones we used were built in house at our plant, I have seen years ago an inline model but do not know the manufacture.
    If i don't find one that works i will build what i need.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Wow, never heard of anything like that. What is the purpose for using weight instead of amperage? There is a place near me that sells odds and end breakers but I have no idea if they would have something like that. www.tampabaybreaker.com/
    2013 PT-200DX
    Ryobi Drill Press
    8" Shear
    6" Bench Grinder
    4x8 CNC Plasma Table
    I need one for a 12 volt winch project i am doing, Needs to break the circuit at 350 pounds, I have made hinge type ones in the past but have seen some that are round , about 4" long.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Oh ok makes sense now. I will give the breaker place near me a call for you tomorrow and see if they know what I am talking about. If they do then I will say great and let you know, lol.
    2013 PT-200DX
    Ryobi Drill Press
    8" Shear
    6" Bench Grinder
    Called two different places and they had no idea what I was talking about.
    2013 PT-200DX
    Ryobi Drill Press
    8" Shear
    6" Bench Grinder
    When you made your own, how did you design them to open at 350#?
    Does this reconnect when the load falls below 350#? Or do you have to do something to reset it?
    These companies make a bunch of load limiters in various configurations.
    http://sagatronic.co.za/
    http://www.loadlimiter.com/
    http://www.saf-lift.com/load-limiter
    Yes it does, I think i will just make one, i have not seen the round style ones for several years. They could have been some type of older military breaker. The ones i have made years ago i used a spring type starter switch from an older car and a spring to make it adjustable on weight, more of a hinge type breaker .
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    So it is really just a load switch, not a circuit breaker type device.
    That last link is the closet thing to what i have made, I will be working on building one and post pics as soon as i get my daughters new kitchen out of my shop, they have been coming out on there days off building cabinets. We are down to spraying the last 2 coats of finish and have to build the Corian Countertops next.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
  1. special trunk for honda crf 250 l
    By donor76 in forum On Road Fabrication
    Last Post: 06-04-2015, 04:02 PM
  2. Tripping one leg of a 240v circuit
    By DaveO in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-01-2015, 12:24 AM
  3. Circuit Breaker Dissection
    By jakeru in forum Personal Projects (no welder required)
    Last Post: 03-22-2012, 05:10 PM
  4. August Special if you mention you saw them here
    By everlastsupport in forum Everlast Announcements, Contests and Promotions
    Last Post: 08-11-2009, 04:56 AM
  5. October special on the NEW units and models.
    By admin in forum Everlast Announcements, Contests and Promotions
    Last Post: 10-25-2008, 01:14 PM
