Results 1 to 8 of 8
Thread: Is there a way to reverse the post order?
    Default Is there a way to reverse the post order?
    The original poster ends up at the bottom of the list. This is backwards from every other forum I've been on. Is there a way to reverse this?
    Never mind. I did a little more digging and found it in settings.
    I had the same issue. For others with the same question, go to 'settings' in the upper right, then 'General Settings' on the left. Under 'General Settings', 3/4 of the way down the page you should see 'Thread Display Mode:' and choose oldest post first to reverse the sort order.
    Cheers!
    Sean
    My review on Youtube of the Everlast Powermaster 205
    http://www.youtube.com/watch?v=Sih-V...7&feature=plcp
    Just a noob having fun with metal.
    Thank you! This was bugging the crap out of me.
    That solves that problem, My laptop was in the right order but the desktop was just the opposite must have been the way they setup. Now i can make them both the same.
    Sometimes you think its a dumb question , but you never know until you ask , sounds like it will help a few of us.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
    Went through the same thing over a year ago - its a dumb default.
    I came here to ask this exact same question... guess I'll go digging too and try to find it. I saw a comic about this the other day, while looking for a solution to a very specific computer problem all the guy found was a description of the problem and then a "nevermind, found my problem" solution post. Doesn't really help much.
    Upper right select Settings, then lower left General Settings, scroll down a little under Thread Display Options, is Thread Display Mode. There you will find newest first and oldest first.
  1. Reverse order is driving me crazy!
    By ironmanjay in forum Forum related Questions
    Last Post: 01-18-2018, 02:51 PM
  2. Replies: 10
    Last Post: 04-27-2013, 01:37 AM
  3. Replies: 3
    Last Post: 12-21-2009, 11:05 AM
