Results 1 to 2 of 2
Thread: Project 1 From CBMKR,Custom Welded Shop Tools And Improvements
    Default Project 1 From CBMKR,Custom Welded Shop Tools And Improvements
    As it would be my luck is just not good when purchasing new tools or equipment, My new RJ-9000 pound bridge jack for my 4 post lift had a bad Cylinder, Over a year old never used out of warranty ,A New cylinder was $249.95 plus shipping. I found a piece of 304 stainless with the right ID and decided to replace the tube. Cut the old base off on the lathe, Turned it around and cut off the top which was threaded for the rod end. Tacked and welded it on with the Power Tig Micro 185, 125 amps, 3/32 309 stainless rod,I just about finished with honing the bore . Will weld on the base tomorrow repaint and install it.Will post more photo's when finished .
Name:	Jack Cyl 2.jpg
ID:	8516Click image for larger version.
Name:	Jack Cyl 4.jpg
ID:	8517Click image for larger version.
Name:	Jack Cyl 5.jpg
ID:	8518Click image for larger version.
Name:	Jack Cyl 6.jpg
ID:	8519Click image for larger version.
Name:	Jack Cyl 7.jpg
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
    Well the cylinder is all done , Finished honing out the cylinder and added a new US Made Polypak seal, Welded the base on with the 185 tig at 165 amps w/309 3/32 rod to get good penetration into the solid base. All back together and it works just fine. Cleaned up and added a little paint.The 304 stainless is a little over kill for material but its stronger than mild steel and i had it here in the steel bin.
Name:	Jack Cyl 8.jpg
ID:	8527Click image for larger version.
Name:	Jack Cyl 9.jpg
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
  1. Replies: 10
    Last Post: 03-02-2013, 04:23 PM
  2. Replies: 12
  3. Replies: 28
  4. Replies: 18
  5. Replies: 12
