Results 1 to 5 of 5
Thread: Input power wire question 250EX
  1. Default Input power wire question 250EX
    What would the recommended type and ga. wire for a 60ft run be?
    Machine is a 250EX.
    220v 3 wire hookup.
    No 8 should do the trick, with a 50 amp breaker, you can verify this by using one of the many wire size calculators available on the web.
    Thank you. I picked up the #8 wire, 50Abreaker, plug, receptacle and Argon bottle today. I should have it wired this weekend and the water cooler should be here Monday.
    Quote Originally Posted by AWDnot2 View Post
    I have ran the stock 2.5 mm^2 cord supplied with the 250 EXT and had no problem stick welding at 200 amps. For power from the main barker, I have the machine tied to a 40 amp breaker with No. 8 wire. The No. 8 wire should be fine as long as it is not too long.
    A 40 amp breaker would not work at my shop on the 250EX as I was getting 208 volts off the 3phase supply and the inrush would pop the breaker, so I had to run over reset the breaker and run back and turn on the 250Ex again so it would run before the capacitators bleed down,,,,worked fine once I got it started,,,,took me a while to figure out that 208 volts requires a larger breaker on the supply side for the in rush demand of the machine...if I had 220 or 240 volts a 40 amp breaker would be fine...
  1. Power iMIG 275P Wire Feeder Alignment Question
    By Baronsbest in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 05-22-2016, 06:01 PM
  2. Power Tig 250EX question
    By 11Bravo in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-17-2014, 03:28 PM
  3. PowerArc 140st input amps question
    By MotoJ in forum Stick Welding (SMAW)
    Last Post: 10-02-2012, 05:34 PM
  4. Input Power Requirments for the 250EX
    By sschefer in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-02-2010, 04:44 AM
  5. PowerTig 250EX input amps
    By JJW in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-04-2009, 04:32 PM
