Results 1 to 5 of 5
Thread: W300 water cooler
  1. Default W300 water cooler
    Does anyone know the coolant capacity of this unit
    Quote Originally Posted by bubbas55 View Post
    About 2 gallons according to the video.
    http://www.youtube.com/watch?feature...XZpsOns#t=205s
    thanks for the reply... just one more ... which is in and which is out or does it matter
    thanks
    ron
    thanks
    ron
    Yes it matters. The W300 is marked with input and output. At the torch side, the output line comes from the dinse connector as it is also the power line. Connect that one to the input on the cooler. The loose water line on the torch is the input, connect it to the output on the cooler. Be sure not to mix up the argon line and the water line. You can blow in the argon line and hear it come out the torch, also watch the video as they have a few other ways to identify the hoses. It would have been nice if they had different fittings or color codes on the hoses, but it's still not a big deal to figure out.
    thanks rambozo... you've been a great help to a noob tig welder.... god knows i'll have a million more questions
  1. AC Power Requirements - 255EXT plus W300 water cooler
    By withanolive in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-23-2016, 07:24 PM
  2. Tig Cooler - PowerCool W300 Question
    By johnnyfive in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 05-03-2012, 10:29 AM
  3. PowerCool W300 = Bad A55 TIG Cooler
    By froader in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-08-2010, 04:52 PM
  4. Added a W300 Cooler
    By Gary in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 08-22-2010, 11:03 PM
  5. Question about W300 water cooler???
    By DisWeld in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-03-2010, 10:28 PM
