Results 1 to 6 of 6
Thread: Spark Container
    Default Spark Container
    Wandering if anyone has tried or made a spark/molten metal container for cutting in a refined area where you don't want the hot material flying all over the place.
    I was thinking about using a 30 gal metal barrel with a layer of sand in the bottom and cutting over the barrel blowing the hot metal down into the barrel.
    I understand you couldn't do any piercing or gouging but simple small cuts should work.
    A 55 gal barrel would be better but would take up more space.
    EverLast 140ST
    PowerPlasma 50
    No You Can't Use Them
    Just use a tray of water under your work piece. That's how cnc plasma and laser cutter rigs keep their sparks to a minimum. It doesn't even need to be complicated, you can even use a rubbermaid tub full if water, because the water cools the slag long before it touches the bottom.
    Spike Customs, Inc.
    Fresno, CA 93727
    ph- 559-549-RIDE(7433)
    -Follow me on twitter!-
    Quote Originally Posted by Spike View Post
    Water is okay for a cnc table. But I don't like using an open container of water close to welding or using a plasma torch. Water would freeze where I'm at, unless mixed with antifreeze. Too cold to mess in water in an un-heated building.
    EverLast 140ST
    PowerPlasma 50
    Dirt or sand will work fine, then. It just won't "catch" the sparks as well as water will. If you're cutting right on top of the barrel you could just use an empty metal drum or trashcan and it will still be really effective.
    Spike Customs, Inc.
    Fresno, CA 93727
    Quote Originally Posted by Gerry View Post
    Yea, I hear that problem. I used to live in Colorado with an unheated shop. Now i'm happy to work in the warm California weather!
    Spike Customs, Inc.
    Fresno, CA 93727
    How about a down draft cutting table?
    http://www.weldingtipsandtricks.com/...-projects.html
  1. First container came in... just now
    By Oleg in forum Pre-sales, Sales and Shipping questions
    Last Post: 09-11-2013, 06:56 PM
  2. DIY : How to make a filler rod storage container\tubes on a $20 budget.
    By watercooler in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-23-2013, 10:18 AM
  3. Spark Gap Contacts
    Last Post: 10-03-2012, 12:50 AM
  4. 250EXT Boat/Container
    By todmorg in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-29-2011, 02:47 PM
  5. Aluminum storage container
    Last Post: 04-05-2011, 05:04 AM
