Results 1 to 5 of 5
Thread: Argon leak inside My new Everylast 205S
  1. Default Argon leak inside My new Everylast 205S
    Had my new Everylast 205S for a week and have been welding with it just fine. What I have noticed is a continues 5 CFH flow at my flow meter, even when not welding. I can pinch the hose to the welder and the flow stops, so I know the leak in not at the regulator. The connection at the bottom of the welder also is not leaking. Anybody have this problem before.
    Quote Originally Posted by bcstexas View Post
    See if you can hear the gas flow at the torch. If you can, the solenoid is not sealing and might need to be cleaned or replaced. If not, you might just have a loose hose connection inside, that can be snugged up.
    Ok called everlast support. They said it would be okay to open it up and look around for a leak. Did so and found the connection to the gauge in front loose, they use the quick connectors on the holes and it was not pushed in far enough. Tested and all okay now.
    Love this welder, it is my first TIG welder.
    Glad to hear it was an easy fix. Sometimes things get bumped loose in shipping, as well. Have fun.
    Hey, BCS, congrats on the new machine. Glad you were able to resolve your leak. Welcome to the forums- what part of TX are you?
  1. New 160STH gas leak?
    By tomm in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-22-2018, 03:21 PM
  2. Powertig 250 EX gas line leak down
    Last Post: 10-19-2012, 10:47 PM
  3. Project 1 from Jason: Windshield Leak Fix.
    By Jason in forum Welding Repairs
    Last Post: 06-02-2011, 05:05 AM
  4. Argon regulator leak
    By robsthomson in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-15-2011, 07:21 PM
  5. Threaded fittings leak solver!
    By dwdw in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-14-2011, 12:47 AM
