Results 1 to 5 of 5
Thread: Using a Carbonator pump/Tank for a TIG Cooler
  1. Default Using a Carbonator pump/Tank for a TIG Cooler
    Been researching building a TIG cooler out of the Procon pump from a Carbonator system. My question is has anyone used the tank that typical is part of the system? It's made of stainles steel and appears to be about 2 Gallons.
    If you searched here you would find a few examples of that.
    http://www.everlastgenerators.com/fo...hread.php/2574
    http://www.everlastgenerators.com/fo...hread.php/2573
    Hmm! Those two did not come up when did a search here, thanks. Or maybe I missed them, you will have that lol. Still debating between building, buying or tap water. For as much as I will be using the 250EX i recently, the tap water route may be the best option for me.
    Repurposing a carbonator is a common route for DIYers to take, and building one may be the most economical way. I've collected the parts I need to build one for just under $200, just need to get over a little design hurdle before I put it all together. There's lots of videos and examples online to take ideas from.
    I noticed there are different model Carbonator's made by McCanns. There are 3 series that are similar, E200, E300 and E400? Anybody know the differences?
  1. Procon Carbonator Cooler Project for 250EX
    By Mikey52 in forum Welding Projects and Pictures
    Last Post: 06-08-2015, 01:46 AM
  2. How much gas is in the tank?
    By jpmitch in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 11-28-2013, 03:02 AM
  3. Procon Pump for Water Cooler
    Last Post: 05-20-2013, 03:40 PM
  4. Tig cooler cooler power source - "warning"
    By Odyknuck in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-17-2012, 10:37 PM
  5. Replies: 5
    Last Post: 06-18-2011, 09:14 PM
