Originally Posted by
braveops
ok its been about 7yrs since i used a tig and it was a 300 miller dynasty we did a lot of alum. ok now to my ?? i need to get a basic idea on how to set up my 205 for some steel tigging 1/8 mat to start with so i will be using the pedal till i get use to using it.what dials do i need to use other than dc/tig switch and amps?? i have downloaded the manual but dont see much for info??
oh ya i have the blue tungsten to
thanx
Ok here is something to get you started using the pedal:
PULSE OFF (then none of the blue knobs will matter)
AMPS 150, ARC FORCE 1 (yellow knobs don't matter for DC), DC, 2T, TIG(HF)
PRE FLOW 1, POST FLOW 10, UP SLOPE 0, DOWN SLOPE 0, START AMPS 5, END AMPS 5
ARGON 6-7 lpm, 3/32" tungsten 2% lanthanated (blue) sharpened to a point.
That is a baseline for .125" wall steel. you will be using about 3/4 or a lil more on the pedal. If your pedal is the kind with the knob, then you will set the 150 on it instead of the panel control.
