Thread: HF when turning on PT 200 DX
  1. Default HF when turning on PT 200 DX
    I noticed when I turn on the unit, there is a arcing on the HF unit in the machine. I read another post that someone else was having the same issue.
    It does seem to be intermittent, sometimes it's fairly noticeable, other times it's very noticeable.
    Foot pedal is not plugged in, and the switch on the torch is not touched. Not sure if it's normal or not.
    Everlast PowerTig 200DX
    Miller 120 Mig
    It's not an issue. It's supposed to do it.
    Cool, thanks Mark!!
    I'm in Dallas for work, my CK 130 torch should be waiting for me when I get back home.
    Can't wait to try it out.
    Miller 120 Mig
    Mine does ti to. You can see it through the front vent grate.
    2013 PT-200DX
    Ryobi Drill Press
    8" Shear
    6" Bench Grinder
    4x8 CNC Plasma Table
  1. Tungsten turning dark gray
    By jtybt in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 10-02-2020, 08:30 PM
  2. Replies: 8
    Last Post: 02-18-2014, 04:11 AM
  3. 200dx spark discharge when turning power on.
    By kayaker43 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-26-2013, 03:02 AM
  4. PP50 wont make second cut with out first turning machine off and on
    By xtreme cartz in forum Everlast Plasma Cutters (PAC)
    Last Post: 01-31-2013, 04:48 PM
  5. Engine turning
    By Ram48 in forum Personal Projects (no welder required)
    Last Post: 06-07-2011, 01:53 AM
