It looks like things are coming along nicely on your build! Even with 200 plus horsepower it should be fun to drive. Granted, if you want to be the wheelie king at the dunes, a turbo will certainly help get you there! It will be interesting to see how close you can get everything to your predetermined dimensions. I always find that bigger projects like yours end up throwing you "curve balls" throughout the process, making it tough to stick to your original plan sometimes.
Is the 2000lb. weight a guesstimate or are you basing that off of another person's sandrail that is similar to your build?
