Results 1 to 2 of 2
Thread: Push vs. Pull
  1. Default Push vs. Pull
    Is there any benefit to pushing puddle and adding filler in front of the torch or pulling the puddle and adding filler behind? I seem to be able to hit the center of the puddle better with the filler when pulling and adding in on the backside. I know with more practice adding it on the front side won't be an issue, but for those out of position welds, does it really make a difference?
    Poewr I-Mig 205P
    Powertig 185
    The benefit is that you tend to preheat the metal and direct your gas coverage better when pushing. You can add filler from just about any direction, but again the area at the leading edge of the puddle is hotter and cleaner. However, for out of position you often have to make exceptions. It's always a good idea to practice with both hands and all directions just so you have those skills when you need them.
  1. 275P and Push pull gun
    By txshockwave in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 12-19-2017, 01:52 PM
  2. Power I-MIG 200 Push Pull Gun???
    By Rafael in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 03-28-2013, 04:52 AM
  3. Project 1.325 CGCINC: Simple Pull-up bar
    Last Post: 06-21-2012, 02:08 AM
  4. Might be an idea: Push button amperage control
    By Luis in forum General Welder Questions
    Last Post: 02-14-2012, 02:54 AM
  5. Miller Push Pul gun with the new Everlast 250P
    By brianarizona in forum General Welder Questions
    Last Post: 01-24-2012, 03:49 AM
