Results 1 to 20 of 23
Thread: NEW 2013 EVERLAST PowerITig 200T DC DIGITAL PULSE TIG WELDER LOW 2AMP START !
    Default NEW 2013 EVERLAST PowerITig 200T DC DIGITAL PULSE TIG WELDER LOW 2AMP START !
    One final announcement that we have to post up about the 2013 models...Another digital unit.
    One of the best niche units we have in our stable is the i-TIG 200. It's found a big following by guns smiths and other specialty manufacturers. It's a reliable, hard working unit with a LOT of capability.
    So we have considered what we can do to make a better product and improve performance and features. So we have developed a completely new I tig 200, which will fall into the digital lineup of welders that we have. It'll have similar features as the 255 EXT but as the i-tigs are DC only, it too will be DC only.
    ONE very special thing it will have is the ability to fire off at an incredible 2 amps. We've studied the market and found that there is a need for this extremely low ignition point for guys that have molds and similar products to repair. It's been a constant request, so we've added this major capability to the unit.
    Here are some comparative specs next to the current i-tig...
    Model Power-ITIG 200 Power-ITIG 200T
    Input Voltage 110/220V 50/60 Hz 220 V 50/60 Hz
    Rated Output 200 A 200 A
    OCV 60-80V 60-80 V
    Duty cycle 35%@200 amps 35% @ 200 amps
    Welding range 5-200A TIG 5-160A Stick 2-200 A TIG 2-160A Stick
    Arc Force 0-10 1-100
    Pulse amps 5-95% 2-200 amps
    Start Amps 15 A fixed 2-150 A
    End Amps 15 A fixed 2-150 A
    Up/Down Slope time 0-5 Seconds 0-25 Seconds
    Pre Flow Time 0-5 Seconds 0-5 Seconds
    Post Flow Time 0-5 Seconds 0-25 seconds
    2t/4t yes yes
    Hot Start arc amp (stick) No welding amps + 1-100%
    Hot start arc time No .1-1.5 Seconds
    Inverter Frequency 27khz 50 khz
    Anti stick function no yes
    memory no 0-9
    weight 16 kg 9.8 kg
    dimensions 425x195x310 mm same
    Protection class IP21s IP21s
Name:	digital itig 200.jpg
    Great looking little DC machine. I love the specs, but am sorry to see you dropped the dual input voltage. For the real low amp stuff, running on 120V can be pretty handy at times. Is this going to replace the current iTIG 200 or is this an additional model?
    Rambozo
    dual voltage will be available in summer
    Oleg Gladshteyn
    Rambozo
    I don't think we are dropping it.
    ~22 lb welder, looks like a nice compact unit with some great new additions.
    When will these be available?
    in stock !
    Oleg Gladshteyn
    in stock !
    What is the price?
    Feb 2013
    Corner of "No" and "Where"
    Minor suggestion - You guys need to loose the nylon carry strap on your smaller units. I'd stick with a rigid handle (going to make one for my PP 50). I don't know of all that many people that would be toting these around like a man purse.
    Sticks
    AKA
    A good many people do actually and several companies use them. Changing to a handle type face cost MAJOR money to recast a panel.
    Quote Originally Posted by sticks View Post
    An easy solution is to pop open the fixed end of the strap and rethread it back and forth a few times through the buckle. Then you have a nice handle sized strap that stays out of the way, and you could still make a shoulder strap if needed. I did that on my little PA140ST because the strap kept getting in the way. It works great and makes a nice handle.
    With the series of tests that I was doing on this welder over the last week I found very consistent arc starts using a 1/16" 2% thoriated tungsten at 3 amps with a amp draw of . 746 amps
    The 2 amp output as stated may show on a multi meter as being correct but the actual low amp is 2.9 amps
    Another really nice feature on this and the new 255ext will be the ability to use any foot pedal or amp control torch regardless of what pot value they use .
    Cheers
    EVERLAST CANADA
    www.everlastwelders.ca
    www.titanwinches.com
    905 637 1637
    Oleg Gladshteyn
    Oleg Gladshteyn
    Is that a 255 EXT in the back gound?
    No, it's the 210.
    Perhaps... but the 255EXT IS sitting behind him on the bench in this vid:
    http://www.youtube.com/watch?v=EnCNIskL5fc
    So where are we at on the 255? The other thread is locked so you might expect questions popping up anywhere.
    Thanks,
    Jim
    He does have 255EXT ... not the final version
    finil version will be ready in few weeks
    Duncan will be testing it at the factory on MAY 15th
    Oleg Gladshteyn
  19. Default
    Thanks Oleg, that is a good update. I Look forward to his reports from the factory.
    Jim
    Any update on the 110v 220v itig200t i recall reading that it should be done around the end of summer.
  1. new 2013 I-tig 200T
    By redstopgreen in forum Customer Testimonials
    Last Post: 01-16-2014, 05:26 PM
  2. NEW 2013 EVERLAST PowerTig 255 EXT AC/DC DIGITAL TIG WELDER
    Last Post: 12-13-2013, 09:48 PM
  3. NEW 2013 Everlast PowerMIG 210 and 200 MIG / TIG DIGITAL WELDER
    Last Post: 02-10-2013, 01:13 AM
    Last Post: 12-24-2012, 12:43 AM
  5. NEW 2013 Everlast PowerMTS 200 MIG / DC TIG/ STICK WELDER
    Last Post: 11-22-2012, 02:20 AM
