Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: Supercut 50 p warning light
  1. Default
    Have had the same issue with my SuperCut50P twice. The overcurrent light and no arc. It is now back getting serviced and have not heard about it for almost a month now. In my opinion, the Supercut 50P is a low end unit, being Mosfit, and the reliability of this unit is poor. Both times I have had issues with it failing, I was not overworking it and I have both a water trap and desicant filters. Like you said, the manuals with it are crap and written by a 3rd grader in China.
    I wish I would have spend a little more money and bought a unit with IGBT.
    Quote Originally Posted by sticks View Post
    33 gallon tank is 4.4 cubic feet. If it takes your compressor more than 1 minute (4.4 cfm) to fill the tank, you need a bigger compressor. In reality is should take closer to 45 seconds to fill to be in the safe zone. CFM goes down as pressure goes up. Look on your compressor for it's CFM @ PSI rating. As the Everlast tech posted earlier, if the pressure dropped too low, the torch could have shorted internally.
    I checked the cfm....It's rated for 6.3 at 40 psi, and 8.2 at 90 psi.
    That would not be possible to have less cfm at 40 psi. Is that backwards?
    Quote Originally Posted by macktruck View Post
    Sending mine back today, I hope it goes well....
    Whoops, I looked at something else..lol. It's 6.3 at 40 psi, and 4.9 at 90 psi.
    What size tank?
    What size tank?
    the tank is 33 gal.
  8. #28
    Feb 2013
    Corner of "No" and "Where"
    Well, we've come full circle, other than you are sending it back, I'd say do the test with the torch disconnected, or disabled, and see if the compressor can keep up with the cutter when the trigger is depressed. Your CFM @ 90 is awful close to the minimum requirements.
    Sticks
    AKA
  1. Supercut 50P Overcurrent light
    By cbmkr in forum Everlast Plasma Cutters (PAC)
    Last Post: 11-05-2018, 02:18 PM
  2. SuperCut 50P On New Steel 7 Ga Light Pole
    Last Post: 08-01-2012, 11:32 PM
  3. I-MIG 200 intermittent shutoff issue (green warning light)
    Last Post: 01-24-2012, 08:34 PM
  4. Supercut 50 over current light
    By outsidegangskilled in forum Everlast Plasma Cutters (PAC)
    Last Post: 09-11-2010, 01:25 AM
  5. Warning Light kicks on easily
    By chuck2302 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-14-2010, 05:52 AM
