Results 1 to 8 of 8
Thread: To Purge or not to Purge
  1. Default To Purge or not to Purge
    I have to get a system to purge the back of SS weldments.
    Option 1: Buy a dual flow meter (150-300$)
    Option 2: Buy a second argon tank 150cf (300$)
    Option 3: Put a brass T fitting running off the tank flow meter.
    Option 4: Make an argon chamber and use a scuba tank for respiration! JK :/
    Any input?
    "The notorious forum spamming troll."
    I combined parts from two of the old style flow meters for a cheap solution. Click image for larger version.
ID:	9848 All you need is two flow meters and a 1/4 npt street tee.
    I saw that on the other thread. That is very resilient of you. Would you describe the operation?
    Actually now I can see it better. The second knob is in the back for the primary regulator. So you can shut off one when not in use with out having to disassemble the set up. Brilliant.
    You get set up ready to weld then reach up to turn on the back purge, weld, then turn it off. That will work fine for me too.
    my back purge setup consists of a t fitting between the bottle regulator and the flow regulator. there is a quick disconnect that i plug a hose into that has a ball valve for turning it on and off which is followed by a needle valve that i adjust flow with and that has a piece of copper tube coming out of it that i use to press into a plastic cap plug. it has worked fantastic for the last 10 years.
    Quote Originally Posted by weirtech View Post
    If you get a chance can you post up a photo of your set up?
    This it's the best way to do it cheaply. Once the chamber is filled, you don't need much flow at all if it's sealed to a small degree.
    Sent from my SPH-L710 using Tapatalk 2
    Soon to be 2013 250EX tig machine
    Lincoln Idealarc DC250 with LN7 wire feeder
    RSG250 spool gun and controller for above.
    Hypertherm Powermax85 with Machine and hand torch
    Bridgeport Milling Machine w/DRO and Powerfeed
    South Bend 9 lathe WW2 vintage
    Devilbiss 6.5hp 80gal 175psi 2 stage compressor
    HF blast Cabinet modified for foot pedal operation better gun.
    Oxy/A torches
    Delta 4x6 band saw
    Hand and power tools up the wazoo.
    The name's "Marcel" in case I forget to sign.
  1. Easy back purge
    By Paul Moir in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-30-2012, 06:14 AM
  2. Dual Flow Regulator for Purge ?
    Last Post: 05-30-2012, 09:38 PM
  3. Using a gas Y for Tig purge line
    Last Post: 03-19-2011, 12:02 AM
