New video ... http://youtu.be/prJh2DOjzSk ... I really need a larger mig system ... and I know just the one ... it's an Everlast pulse system ... duh ... ya think? ... ROFLMAO![]()
Powertig 200DX
Lincoln 180c
Hobart Handler 125
and a bunch of other tools
What's the material cost on these ?
Links to my welding projects > : Spray Arc with the 250p : Coldsaw Stand : Welding Cart : Heavy Duty Rolling Shelf : Taller Bandsaw
I calculated my expense one these bars ... so far I used up 5 and a half feet of re-bar my cost 10.90 and 8 feet of 1 ½ X 1/8” flat stock apx. $7 or so (I believe) at this point I have $17.90 and I’ll probably put in another $10 bucks for mounts and a pad lock so my total cost on materials should be no more around $30 per set including paint. The price I mentioned before was was just a guess on materials to that point … I broke out the calculator and figured it out ... still in all … cheap insurance.
Powertig 200DX
Lincoln 180c
Hobart Handler 125
Last edited by Winky; 04-30-2013 at 11:19 AM. Reason: it's 3 AM and my brain aint working well lol
Powertig 200DX
Lincoln 180c
Hobart Handler 125
Actually to clarify that I did two sets of window bars so double the amount of material ... my first est. was close the two would be around $30 or so ... was fun to make that was the BEST part. I'm going to set it up with three pins that drop into holes and the fourth mount will be a pad lock covered so no one can take bolt cutters to it ... the pins will be too thick for bolt cutters (and least reasonable size ones). I love Coyote Steel Co.if I had gone to a hardware store it would have cost 4 or 5 times more. When I buy from Coyote the prices are so good I but in bulk saves me a lot.
Powertig 200DX
Lincoln 180c
Hobart Handler 125
Now, if you could just weld razor blades to the tips....
Mark
877-755-9353 x204
M-F 9am - 5pm EST
Just off of a main street where there is a low income apt complex full of tweekers and gang land central ... our neighbors are OK but a block away ... not so much. I've put in cameras, a security system, cyclone fence, reinforces frames around dead bolts, center shafts on sliding doors and now bars ... paranoid? Perhaps, ready to take out scum bags? Absolutely!![]()
Powertig 200DX
Lincoln 180c
Hobart Handler 125
Nice project and video Winky. Maybe time for a 205PBetter 250p. Far as the scumbags, the Ruger should help out there
Mark's blade idea is good. How about AC power to it as well They can shake and get all cut up on them. It will save you a couple rounds.
I've been thinking about a 205P ... it would really be a nice addition t my shop ... that and a laser engraver would be awesome![]()
Powertig 200DX
Lincoln 180c
Hobart Handler 125
