Results 1 to 15 of 15
Thread: Hello from Utah
  1. Default Hello from Utah
    Hi forum people, my name is Charlie. Looking to get a 250ex/300cooler combo. I am planning on doing some 4130 tubing and 6061 aluminum for some custom vehicle work. Should be nice, see ya around.
    Welcome to the group,good choice 250EX & cooler.
    Welcome the4th. That is a great combo. I have had two of the 250EX units for over 3 years. I have our digital unit as well, but always seem to go to the 250EX. The power is great, plenty of easy to see knobs. Good choice like Geezer said.
    Hey, Charlie, welcome. +1 on the 250 ex and cooler, heard nothing but good reviews. Post up some pics of projects, i you've got em!
    Welcome to the forum and +1 on the 250EX.
    Very cool! Welcome to the forum Charlie. Give that 250EX a workout and as mentioned, post up some pics for us as you finish them!
    Good Choice, I have the pp256, very similar to the 250 with less duty cycle. Been looking at building a water cooler, but gave up, and will just order the 300. Can't beat it for the price.
    Everlast PowerPro 256 (2013)
    Northern Hybrid 200 & ST80i
    HF 90Amp FluxCore (Don't laugh, it is what got me started)
    Lotos LT5000D Plasma
    HF 4x6 Horizontal Bandsaw
    Rikon 18" Bandsaw w/VFD
    Delta 14" Drill Press
    Robland NLX31 Euro Combo WW
    Great combination but I think you've already heard that! ;-)
    Welcome to the Everlast forum.
    I'm in SLC and own a PP256 and 300 cooler. I'd offer to have you over and give them a test drive, but they're still in the box waiting for me to run a 220v line. Maybe this holiday weekend...
    Sent from my PC36100 using Tapatalk 2
    Just a new guy that wants to make stuff.
    PowerPro 256
    Hey thanks allot you guys. Just barely pulled the trigger on all the goodies. 250ex/300cooler/cart/upgraded regulator and flex lines. They said it should be around 3or4 weeks from now. I will take the foot pedal with a grain of salt for now. Knowing full well that I will upgrade it soon. The upgraded package has flex lines and a better regulator, the lines are only 15 feet long, so this will be upgraded soon too. I will be getting a 250amp ck flexloc with 25' flex lines asap. But a fixed torch on 15' lines is fine for now.
    Im tired of putting the motorcycles away for more than half a year because of our Utah winters so Im working on a rig for winter. Its pretty ambitious with allot going on and I have a long way to go. The only welding done so far is the machine that I am using to make the 6061 rims for the "Nemesis" Hey if you can make the rims the dash wont be a problem right?
    Teaser pics: Like I said I have a long way to go.. Its a 3 piece wheel, this is the spoke section with the outside bead. This bead has bead lock from the inside when the next ring squeezes together.
    This is the backside of it. I am working on the wooden mock up brake disk spacer/adapter. This is a complex piece. It mounts to the back of the lug face and gets around the hub bearing mounts with that clover shape then excepts the bolts from the front. It has to clear the bearing mounts so the wheel can turn, space the disk away from the backside of the rim spokes to make room for the caliper, of course mount the disk, and keep the disk hardware clear of the upright/steering knuckle. Not allot of room to accomplish all of this. The effort has been worth it though as now I wont have remove any brake parts to remove the wheel. It all stays on and is mounted behind the hub flange (lug area) Of course the final part wont be plywood it will be 6061 alum.
    There are allot of very talented people on the interwebs with incredible skills and I have a long way to go but this is the (without a doubt) NICEST thing that has come out of my basement ever. There are engineers and all kinds of professional people that Im sure will find lots of faults with this design/idea/execution but I have to do what Im capable of doing. I dont have huge budgets with 500,000$ worth of software to work with YET. Im just getting started and like I said I have a long way to go. I designed that piece cad/cam'ed it then cut it on a machine that I built (with help from the interwebs ) I am all self taught and funded right now. I guess what Im saying is: Just keep in mind this is very early on, it still has machine marks on it and its way over built. The last thing I wanted to do was spend lots of time/money on four RIMs only to risk safety and have them weak/bend/break. I will live with the fact that it may be overbuilt rather than trimmed completely down for performance in the interest of safety. I mean its a rim for hells sake. NOBODY makes rims in their basement. (your thinking ... "There is a reason no one does" . maybe..?) Well nobody I know anyway.
    Although there is no welding on this piece there was just no way I was going to ruin parts like this with some half azz method of welding aluminum. Watching pete pound up and weld that aluminum gas tank with a bic lighter and some strips of material and flux was truly inspiring, but...I dont see me doing that. (ok it wasnt a bic lighter but still ...)
    Greygizmo we should definitely get together sometime. What are you making?
    Thanks for taking a look guys and I appreciate all your comments.
    Well no edit function (that I could find) so I guess we are stuck with that post the way it is. I know the internet loves pictures but those are not welding pictures. Oops.
    Greygizmo I clicked your profile page and found out you are a structural engineer and therefore my new best friend . I dream of the day I own solidworks.... one day.
    Edit: I guess edit is timed? I could edit this post..*shrug*
    Quote Originally Posted by The4th View Post
    My project list is long, and grows longer by the day it seems. Most of what I'm doing right now is home improvement type stuff - welding kitchen cabinets might be my first real project (I don't really have any welding experience).
    I have a lathe that is CNC-retrofitted but needs new motors/controls and a knee mill I'm rebuilding and want to CNC as well. I also have a 40W laser cutter that is 90% done. Looks like you are into bikes - I have a CB750 I want to tear down and rebuild, and I have a race engine I need to drop into my VW.
    I enjoy CNC and my real passion is in machine design. I actually teach SolidWorks and CAMWorks. What type of CNC machine did you build?
    PowerPro 256
    Thanks m j mauer.
    Yea the cnc world is just fascinating. I truly love it. I would say Ill help retro fit those units but it sounds like you are covered, I will hold the flashlight and hand you the screwdrivers so I can learn a few things .
    My machine:
    Mach3-serial cable
    Pmdx bob 122 I think?
    Gecko drives 203v
    7.2/1 steppers on rack and pinion.
    4'x8'x10"z all steel router table.
    Welded in place and its a beast. (well for me anyway) Im sure a knee mill is no pansy either.
    Its time to get the stepper gearbox's out of the picture. They served their purpose and Ill keep them for a plasma table or something. So I am making changes to my table in between cut jobs. I could go on and on ... Ill spare the internet of one more rambling guy online, but I do think we need to talk more. There is no question that you could help me in allot of ways the only question is: How can I help you?
    Are these machines of yours in your classroom/shop? What time should I be there?
    *Passion in machine design* --- Man that is really speaking my language.
    Nice to meet ya.
    Welcome to the forum ... this is a gr8 place for welders from nube to old hand
    Powertig 200DX
    Lincoln 180c
    Hobart Handler 125
    and a bunch of other tools
    Thanks m j mauer.
    My machine:
    Mach3-serial cable
    Gecko drives 203v
    Nice to meet ya.
    Well you've at least finished a machine, so you have the upper hand there! It sounds like we have similar interests and could probably help each other. Feel free to shoot me a message, I'd like to see that router of yours. I live in downtown SLC.
    PowerPro 256
  1. Complete noob from Utah
    By Glen in forum Introduce Yourself
    Last Post: 07-23-2013, 07:17 AM
