Just a heads up. Be sure you have the hot and neutral on the correct poles on your adapter. It is kinda counter intuitive as to which is which because the blade/color standards are different between 240V and 120V. You want to make sure that the neutral is on the white wire of the welder, which will be the narrow blade on the 240V plug but the wide blade of the 120V plug.
