Originally Posted by
Since the fence is decorative it's probably close to a power source... is that correct? Just thinking about power, whether you can plug directly into 110v or 220v, or if you'll need an extension cord. I've read here on the forum about the IMIG 200 working well on 110v at the end of a fairly long extension cord, too.
The fence is at the back of the property so the nearest power (only a 20A 115V) outlet is about 35' from the fence. Given the thickness of the tubing I suspect this outlet will be sufficient for the job. ??? I also have a 25' 8 gauge extension cord which I would have to make an adapter for.
I need to replace multiple pieces of the fence but we don't have any wind (in the morning) here so I think non-flux wire with C25 would work. I might pick up a small bottle (~40 Cu-ft) rather than transport a bottle. That said, I think I'll try some flux core 0.030 wire to see how if works. Just a newbie here trying to get my welding seat time up.
cheers
JohnG
imig 200
PowerTig 210 EXT
