Results 1 to 15 of 15
Thread: Duty cycle
    Default Duty cycle
    On these machines, do I have to be counting duty cycle, or can I just weld until the thermal shutdown kicks in, then give it a rest?
    Heat is the arch enemy of semiconductors. You can finds scores of graphs and curves of temp and lifespan. So for the most longevity you would be wise not to rely on the thermal sensor. It is on the heat sink and it will take time for it to reach the trip temp while the actual junctions continue to heat up. There is also hot soak and many other factors that come into figuring out a duty cycle. For some production shops, time is the most valuable asset and they will burn up machines pushing them to the limits routinely, then just swap out units when they die. For most of us, we run at a slower pace and it's not hard to stay under the duty cycle. Things like ambient air temp, humidity among others, can also effect duty cycle. If you are working your machine hard, give it a rest before it demands it, and it will give you many years of good service.
    Everlast welders have huge fans andheat sinks which increase their duty cycles over some others,,,,if you can weld to the point that exceeds the duty cycle ,,then you are one hellva welder and should slow down cause you are working too hard..or maybe come over to my place I could use a guy like you..
    Understand Duty Cycle
    What is the definition of duty cycle?
    The amount of time in a ten-minute period that an electrical device can perform work without overheating.
    One way of classifying a welder's "size" is by how much amperage it can generate at a given "duty cycle." Duty cycle is the number of minutes out of a 10-minute period a welder can operate. For example, the Everlast 250EX TIG unit can deliver 250 amps of welding output at a 60 percent duty cycle. It can weld continuously at 250 amps for six minutes, and then must cool down during the remaining four minutes to prevent overheating. Six minutes of welding at 250 Amps is a lot of welding but at 200 amps it can weld at 100 percent all day under normal conditions with out over heating.
    Running your welder to the duty cycle is like running your car to the redline in the temperature range and then letting it cool off. Do that routinely and intentionally and you will have a car and welder with issues.
    That's really what I was wondering. "Is the thermal shutdown point the red-line, or is it some point less than that?" Seems like I've got my answer. Maybe I should invent a "duty cycle timer". It could sense the arc and count how many minutes out of ten you have been welding, and tell you when to stop. I'll be rich!
    So, let me ask a different question then: how do y'all track your duty cycle? I know you're not out there with a stopwatch. Are you just winging it?
    I buy a large enough machine for my usage that I don't have to worry about it too often.
    What type of welder is it and what are you welding?
    Duty of a welder shouldn't really ever be an issue at all unless you are using it commercially. It is difficult to use a welder at full output for a long period of time unless the welder is too small for the job you are trying to do with it.
    Duty Cycle by Everlast on a PowerTig 250EX
    The duty cycle has been determined for the 250 EX (220/240 V 1 and 3 phase ). For the 250EX, the duty cycle is rated for 60% at 250 amps. The duty cycle is based off a 10 minute duty cycle rating at 40° C. This means that the unit is capable of being operated at the stated amps for 6 out of every 10 minutes without a break to cool down the unit. This does NOT mean that the unit can work 60% of any greater length of time. A full 4 mi-nute rest should be given to the welder for maximum life. The temperature light will come on and the welder will automatically stop welding when an overheat condition has occurred. If the light is on but the unit does not stop welding, this does not necessarily mean that you have not exceeded duty cycle. Heat will continue to be generated by and transferred to the electronics after welding has ceased. Welding in humid, or hot conditions can affect duty cycle as well. Do not shut down an overheated welder until it has safely cooled. Once the overheated condition has cleared, welding can resume. Do not oper-ate the welder with the covers removed.
    I think if you have to keep running your welder at full power you need a bigger machine.
    I could use a bigger machine but I only have single phase 220V can get the voltage up to 600V with a transformer but still only single phase.
  1. PP80S Duty Cycle
    By Tallguy64 in forum Everlast Plasma Cutters (PAC)
    Last Post: 07-03-2017, 01:13 AM
  2. cool down/duty cycle
    By ogre in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 12-19-2013, 06:07 PM
  3. Power arc 160 STH duty cycle?
    Last Post: 06-15-2013, 03:45 PM
  4. 256 duty cycle
    By Blaze in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 08-27-2012, 07:14 AM
  5. 100% Duty cycle
    By stick in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-09-2011, 03:07 PM
