Hi all,
I have a 160STH that I like, but the torch cable is a bit cumbersome. Getting a new torch with the superflex cable is a bit expensive (around $100), Im wondering if anyone has made the investment and if you think its worth it?
Thanks,
Jon
Hi all,
Thanks,
Jon
Here is what someone had to say on another forum I frequent:
Every single other commenter on the thread agreed. Do not wait. Buy immediately.I just wanted to say I've been using a WP-17 tig torch with a two piece cable (vinyl gas and rubber power). I recently purchased a one piece ck superflex braided hose and adapter. The adapter is super high quality and the hose is amazing. It literally makes it feel like you are holding nothing other than the torch. I had to look to see the hose didn't fall off while I was welding! Makes it so much easier.
If you are thinking about it, don't delay, go buy a superflex hose...so worth it. I'm upset I've waited this long now. It really makes tig welding so much easier when it is no effort to put the torch where you want to.
One thing: the superflex seems to be a one-piece cable, whereas your PA160-STH has separate power and gas hookups. I'm sure the helpful folks at Everlast can point you in the right direction for solving that problem.
Found it!
http://www.ckworldwide.com/technical.htm
A one piece hose can be used with an adapter that plugs into the Dinse connector on the welder and has a short gas hose that plugs into the gas outlet on the welder.
Ck 17 torch with 12 1/2 foot super flex
http://store.mwsco.com/storefront/CK...rFlex-P-617209
Picture of a male Dinse to connect 17 torch to 1/2 Dinse. The red super flex cable screws into the connector. The short black hose is the Argon hose. It may need a Everlast style quick conecter.
http://www.weldfabulous.com/p-77559-...17mr70-qd.aspx
Cable joint change Not sure this will work but is shows the connections. Scroll down for a good picture.
http://www.ebay.com/itm/WP-17-SR-17-...item5d324376a0
The 160STH may take the small size Dense.
But will the two piece cable be as awesome as the one piece is reputed to be?
CK Superflex is only available as a one piece for air cooled or a three piece for water cooled.
CK DINSE adapters are available with Everlast quick connects pre-installed. See the Everlast YouTube channel for a video with all the proper part numbers.
The cable set is what determines how many hoses/cables. You can switch a two piece setup to a single by changing the cable. The connections at the torch are semi-standardized, but you will see differences from brand to brand.
You guys are over thinking this... just call Everlast sales. I would order a CK130 flex complete or even better the CK FL130
These torches are rated at 130 amps 100% duty cycle both AC and DC so I think 160 amps at 35% duty cycle should be a problem. I still use the one I got for my pp256 (sold) on my new 250EX http://www.everlastgenerators.com/fo...ad-on-my-PP256
Mine...
Hey Zoama, it seems that some safeloc DINSE come with a short argon hose while others have a 6' hose, both with QD fittings. Do you know the portion of the part number that specifies that?
I cut the one in my pic and put the Everlast fitting on it. I talked with Sjon Delmore at CK about the proper length gas line for Everlast machines and he agreed to make them 18" but since then several people have gotten 6' ones.
I'm sure by now that Oleg has got Sjon to come up with a better suffix for everlast than the previously used "LG". In any event the gas line now comes with a qc that has a screw collar to secure it, so shortening the hose takes about 30 seconds.
