Thread: Anti-roll bar link mounts
  1. Default Anti-roll bar link mounts
    Small and not particularly cool or fast, but hey, it's On Road Fabrication! I made up some control arm mounts for some 3/8" front anti-roll bar links. These are cut from 0.090 CrMo sheet.
ID:	10561Click image for larger version.
    I tacked a bolt through the bottom plate as a mounting stud, then mocked up and tacked up.
ID:	10563Click image for larger version.
    After welding them up, I cut the studs down to length and added a quick coat of Krylon.
ID:	10565Click image for larger version.
    Here's a shot of the mounted configuration:
    Turned out real nice, well done. Can I ask, what are you using to cut the half circles out of the end in picture 2 of 4? Those are some clean cuts.
    Just a hole saw and then dressed them with a sanding roll. I put a 7/8" hole in the center of a 1x2 piece then cut it in half to make two parts.
    Nice, I like the adjustability that they have and that will have some positive effects. Should be nice and stiff without any rubber bushings too. I changed my factory rubber bushings to poly inserts.
    Preload is bad, so adjustability is a must. The purpose of this was actually to relocate the mounts inboard and reduce the effective rate of the bar.
  1. 4bt Cummins motor mounts
    By dzljon in forum Other Custom Fabrications
    Last Post: 08-31-2016, 07:14 AM
  2. Aero bar mounts
    By Rambozo in forum Personal Projects (no welder required)
    Last Post: 07-10-2012, 03:28 AM
  3. Automotive Anti-Swaybar Bracket Repair/ Reinforcement
    Last Post: 04-18-2011, 03:40 AM
  4. Shackle mounts
    By roadymi in forum Off Road Fabrication
    Last Post: 09-24-2009, 01:48 AM
  5. LINK: Everlast TIG work on weldingweb.com
    By everlastsupport in forum Customer Testimonials
    Last Post: 08-05-2009, 01:04 AM
