My 60s used to go up to 60amp max power when I first got it, now with the dial turned all the way up its only reading 50 amps tops. Thinking there might be something broke in the machine
When the knob is turned to the low setting will it read 20 Amps or is it different also.
It could be a simple adjustment issue.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
How do I make this adjustment ? It's low limit ( should ) be 20 but it actually goes down to 10A on the digital read out, and only 50A max on the high when should be 60? Any help would be great, if not ill have to call everlast on monday
You can try tech support tomorrow and leave a message, and if they are able, you might get a call back. The adjustment is inside, and not the best thing to describe here. Over the phone would be a lot quicker, better and reduce chance of you getting the wrong adjustment. Have you tried to cut with it and LOOK at the display while cutting? That'll tell a lot as well. It'll read actual cutting amperage while cutting.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
I haven't watched the readout while cutting I will try that today if I can't a chance, but regardless I will give you guys a call soon and get that sorted out. Thanks for the help![]()
