Thread: Clean-Up after Jig Saw cuts
  1. Default Clean-Up after Jig Saw cuts
    I use a Jig Saw to make most, if not all of my cuts. I notice a little contamination at times, especially when starting and or tacking. The cuts are straight but too rough to wipe down.
    Do you guys suggest filing smooth so I can Acetone wipe or just Stainless brushing?
    Interesting idea- just so I'm clear, you use this on aluminum? If the angle aren't too great you might use a flap wheel.
    I try to use a carbide deburing tool on a die grinder if possible, if not i use a clean file to smooth things up. Jig saws and band saw blades tend to leave unwanted dirt and debri in the area where you did the saw work.
    I just repaired a rigid pipe fitting tool used to pull 2 pipes together the aluminum handle had one lug busted off and i had to use a coping saw to remove what was left. The Die grinder did a great job cleaning it up and i made a new lug from a piece of 1/4" wall aluminum tube welded it and the repair worked great.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
    I've given some areas a shot of acetone and then hit them with a wire brush if the area is a little rough.
    Great idea's. Thanks!
    Yes my experience with grinding disc's flap wheels ect is the amount of foreign matter they leave on the material, Next to a Stainless steel brush the carbide tool is the best way i have found to clean up aluminum for welding. My cutoff saw has a Non Ferous saw blade in it and leaves a clean cut that just requires acetone.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
  1. Clean or shine Aluminum on the cheap
    By 5440 in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 03-28-2013, 10:43 PM
  2. Best way to clean old aluminum for TIG
    By jtybt in forum General Welding Questions
    Last Post: 03-13-2012, 01:18 AM
  3. Clean an electrode holder?
    By posixPilot in forum Stick Welding (SMAW)
    Last Post: 02-15-2012, 01:18 AM
  4. Only cuts after post-air quits
    Last Post: 02-07-2012, 05:58 PM
  5. smooth plasma cuts
    By worntorn in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 06-29-2010, 09:58 PM
