Results 1 to 11 of 11
Thread: SuperCut 50
  1. Default SuperCut 50
    It will work fine then I stop cutting for 10 min. Then I get none thing it only blows air out what's up with it.
    I found my Electrode lose could that make it not arc
    some torches have a safty built in, if you have a brass ring on the torch cover that is what its for. If the tip is loose it will not fire. There are clearances inside the torch the need to be held, if not you will burn the consumables.
    Everlast PM256
    Millermatic 180
    Longevity Force Cut 80I
    13" metal lathe
    Small Mill
    ect, ect.
    Now it does none thing no arc no none thing but air.Were do you take these machine for warranty work.
    Quote Originally Posted by 1960plumber View Post
    I had a resister blown on my board that caused the same problem. fixed the resister and the machine works fine.
    If you think you need warranty work, you should call in to Everlast's main number and ask for tech support. They will walk you through some troubleshooting steps that may get you sorted out, and if they can't sort it out, they'll issue you an RMA for a return. The warranty work is performed by shipping the machine back to Everlast. I don't think there are any local service centers or anything like that.
    Note: I'm not an Everlast rep. Just trying to be helpful.
    Thank you both for your answer I have called tech support and i'm waiting now for them to call me.
    When you send something in for warranty work when will they e-mail you to tell you what's up.
    It will be repaired and sent back. If you want to check the status, you can email status@everlastwelders.com or call the toll free number on the website (877.755.9353) and ask for ext 202 or 207.
    Thank you !
    WOW Just talk to them and they told me they couldn't fix it they would be shipping me a new one out wednesday. That was to easy Thanks everlast
  1. SuperCut 50
    By MigPlazArc in forum Customer Testimonials
    Last Post: 09-21-2011, 02:14 PM
  2. SuperCut 50P
    By Tritium in forum Everlast Plasma Cutters (PAC)
    Last Post: 05-06-2011, 07:23 PM
  3. supercut 50
    By IAN in forum Introduce Yourself
    Last Post: 02-10-2010, 06:19 PM
  4. supercut 50 came in...
    By mfggunner in forum Customer Testimonials
    Last Post: 10-11-2009, 12:21 AM
