Results 1 to 2 of 2
Thread: tig welding a fillet weld help
  1. Default tig welding a fillet weld help
    can some one give good directions on doing a fillet weld on steel. torh angles?
    I try to stay vertical, not more that 10-15 degrees from there. Also, I like a short stick out normally 1/4" or less. Push the pool.
  1. How to weld TALL weld beads on 1.6mm thick Aluminum Tube?
  2. Replies: 4
    Last Post: 11-09-2012, 02:15 AM
  3. First Attempt at an Aluminum Fillet Weld
    By blasphemy000 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-11-2012, 10:30 PM
  4. Some weld pictures I took of welding
    By MigPlazArc in forum Hobyist Projects
    Last Post: 07-05-2012, 03:34 PM
  5. Penetration of weld and weld build up?
    Last Post: 07-03-2012, 08:06 AM
