My old boss blew out three power cables within a week on a brand new Syncrowave. For two different reasons, but it still boils
down to the same thing. You either need to have a fuse block, a coolant flowmeter in the welder, or wire the cooler to come on with the welder. Forgetting to turn the gas on is embarrassing, but pretty painless, forgetting the cooler is a meltdown. Yes, you can get replacement power cables. They usually go first but there is also a slim chance of torch damage from lack of coolant, so check it out good when you have it apart. Check for proper coolant flow and any leaks.
