Results 1 to 8 of 8
Thread: Cooler alternative
    Oct 2013
    Glendale Arizona
    Default Cooler alternative
    Purchased a water cooled torch, not that I'll use it that much with the PP 205 but I really like how small the WP-20F is. Came up with my version of the tap water system that works great. Pics are of the welder connections, the shop sink water source, backyard drain and I threw in one of my tig finger holder. Someday maybe a real cooler but this is just fine for now. Click image for larger version.
Name:	cooler hoses.jpg
ID:	11708Click image for larger version.
ID:	11709Click image for larger version.
ID:	11710Click image for larger version.
Name:	601 tig finger.jpg
    Nice...I like the drain.
    There you go.
    If nothing else you get a little heat in the pool too. Slick.
    Are you running argon through the water trap/pressure regulator on back of the machine ?.. It's looks that way in the pic. Argon should go from your flowmeter directly into the machine.
    Oct 2013
    Glendale Arizona
    Are you running argon through the water trap/pressure regulator on back of the machine ? Zoama, That only happens when I forget to turn that shutoff, there are 2.
    I see you have a GM weather pack connector at the front of the machine looks like it is going to the control plug what is that for? Nice work on the plumbing.
    Oct 2013
    Glendale Arizona
Name:	2 pin connector.jpg
ID:	11728Kempy, I had some of these 2 pin weatherpac connectors and no 7 pin plugs for some new torches. I did the cheap way out for the new ones. It actually works just fine.
  1. tig cooler
    By postmark in forum Welding Projects and Pictures
    Last Post: 01-07-2015, 01:26 AM
  2. Tig cooler cooler power source - "warning"
    By Odyknuck in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-17-2012, 10:37 PM
  3. TIG 200DX Alternative Pedal Option
    By compression in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-18-2012, 07:12 PM
  4. Replies: 28
    Last Post: 03-29-2012, 06:16 AM
  5. Alternative tig torch selecton for pp205
    By rodjava in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-04-2011, 08:24 PM
