Results 1 to 20 of 28
Thread: My Power Plasma 50
  1. Default My Power Plasma 50
    Just got my PP50, hooked everything up and it worked right outta the box.
    Tested it on some 1/8" angle. Dang it's neat!
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Already made a tow bracket so I could connect a tow bar. Wasn't easy cuz there's no frame to the car. Just stamped sheet metal so I had to make it a bolt on frame rather than welding something to a bumper or frame.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Post up some shots if you get time.
    What does it mean when the arc turns off. Sometimes it shuts down after only 1-2 seconds (cutting welds(disassembling) .040" sheet metal tubing). Then I went over to a scrap 3/8" steel and even forgot to attach ground and it cut without interruption.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Quote Originally Posted by jtybt View Post
    Could be moisture in the line, oil maybe. Bad consumable can cause it as well. What the air pressure set at? Try it at 60-65PSI.
    Without the clamp, you're cutting with the pilot arc. I have done that many times on thinner steels or to clean up a cut (on propose most of the time).
    Been having trouble with air hoses leaking and popping off. Re-crimped the clamps but just popped off. Going to get hose clamps today.
    Also, where is the 'CODE' for registration purposes?
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Holding air now. Starting cutting fine then stopped. Everytime I press the trigger, the air pressure in the torch hose goes to zero and no arc.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Tried it again. Nothing. Post flow timer doesn't work either. Flows about 15 sec no matter what setting. Amp control has no effect on torch.
    Pressure regulator isn't working either. Pressure stuck on 60 PSI.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    are you sure you are pulling out the reg knob to turn the regulator, that knob is one hellva tough knob to pull out. Check you ground connection at the machine, I had a similiar issue. the reg knob can drive you nuts. try pushing it in and then pulling it out etc.
    Yeah, the air flow reg knob is a bitch. I leave it out. It doesn't turn when pushed in.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    The pushed in position is the locked position, it can only be adjusted in the out position. I leave mine out as well, Question ?? what hoses were leaking and had to be recrimped , are we talking in side the machine or out side on the air cleaner etc. The air pressure setting from the compressor is not supposed to exceed 80 psi. if I remember correctly. I remember reading that somewhere in the instruction manual.
    Compressor is set at 80 PSI and the plasma is stuck at 60 PSI...but that's not the problem. There is no arc or pilot arc. I hear a solenoid in the machine and all air pressure in the feed line to the torch deflates.
    The air hose to and from the air pressure dial was leaking but took a re crimp fine. The hose to the'solenoid'(?) blew off so I put a small hose clamp on and it held.
    After these fixes, the torch fired and cut two spot welds off and then stopped with the deflate of the air supply to the torch.
    I called Mike a couple times and missed him. He called me today and I missed him.
    Got a hold of mark and he suggested the hose clamps...but they have to be modified(bent) to close on a 5/16" hose.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Interesting problem, could be a sticking relay/bad relay connection, or perhaps the consumable is pitted and welding it self to the tip, the pilot arc torch has a sliding tip on a spring, anything gets in there could give you a problem. My problem occured when I used a fellows compressor that was loaded with water from not draining it regularly, the little filter grabbed a teaspoon of water in two minutes of use. Used my own compressor and the problem stopped.
    Interestimng. I'll hook up my water trap/water filter for my paint gun and switch over to my pancake compressor and take to tip apart....but I think it's an electrical problem at this point, with the torch hose deflating when I pull the trigger.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Jan 2010
    Chugiak , Alaska
    Not to jump in here, hopefully you’ve heard from Mike. The unit will shut down the arc if there is not enough air flow, for safety. From what I’m reading it sounds like you have a restriction in the air line to the solenoid, I’d take a good look at the regulator or air line to it. Look for Styrofoam in the reg. inlet. Also look to see that the regulator is not coming unscrewed at the body (from turning the knob). Hope this helps.
    Ray
    ____
    Ray
    support@everlastalaska.com
    www.everlastalaska.com
    877-755-9353 X207
    Good input. All suggestions will be happily looked at.
    I just started the plasma inside the garage and noticed the yellow light was on. Didn't see it before cuz I was outside.
    Also hear a high pitched, almost inaudible buzz when I pull the trigger and the torch hose deflates.
    Haven't heard from Mike this morning. I'm on the west coast(30 mi from the warehouse) and I think Mike is in Florida so there's a time difference.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Have you checked the tightness of your consumables? Loose consumables are the primary cause of the condition you described.
    The main issue outside of that is a torch malfunction. Carefully inspect the two pins at the top of the torch head when the cup is removed. They look like to fine ballpoint pen tips sticking out. They should move in and out freely and point straight. The next thing to check is the "plunger" action of the electrode. If you press in on the electrode, it should rebound quickly. If it rebounds slowly or not at all, you have a problem. Also, in twisting the torch or using it, occasionally a wire comes off inside the torch body itself. 4 screws will open it up along with a gentle twist on the bottom of the torch body to unscrew the plastic fitting that is attached holding the torch together. Look at the attachment points and the trigger wires. You can see if the wires have slipped off the terminals or not, and inspect the solder points of the power AND pilot arc wires.
    The yellow light is on...its a good thing, tells you you are in the correct pressure range.
  18. Default
    Pulled off the cup and blew thru the tip and assembled. Works now, BUT the post flow timer doesn't work. Turned it all the way down to check and it still blows about 15 sec.
    The pilot arc runs fine until I attach ground and start to cut. The arc shuts down. Sometimes after 2 secs or 5 secs, but it always shuts down with the ground attached to the work. Sometimes it will restart by itself. Everytime it shuts down, the air hose to the torch deflates.
    The inner tip spring seems to work but one pin feels a little rough.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
    Sounds like a crud problem in the hose, probably stuff in the hose during manufacturing, a tiny bit of crud can affect the swirl ring or piston especially if the air is wet coming through making the crud in to a sticky paste. Keep us informed, new knowledge and fixes are good for others to know.
  20. Default
    One curious thing. There is a 1-2 sec delay after pulling the trigger til the pilot arc starts...but every once in a while it'll start as soon as I pull the trigger.
    I have a refillable aeresol can from HF that I can fill with lacquer thinner and spray the torch tip parts and maybe un stick them.
    I'm disassembling some tube type wrought iron fence to build up some stock but it also gives me practice in cutting thin stuff and tack welds without going thru...well most of the time.
    I have a bunch of 3/16" X 2" angle iron brackets I have to disassemble, too.
    Gotta make this plasma cutter pay for itself.
    Charlie
    Everlast 225 LX
    Everlast PP 50
    HF 130 TIG/90 ARC
    HF 90 fluxcore
    ATX MIG (don't ask)
  1. Power Plasma 50 or 60c
    By MoJo1917 in forum Everlast Plasma Cutters (PAC)
    Last Post: 11-23-2012, 12:00 AM
  2. Power Plasma 50 plasma cutter....
    Last Post: 07-20-2012, 01:58 PM
  3. Power Plasma 50 help.
    By dean_af in forum Everlast Plasma Cutters (PAC)
    Last Post: 10-04-2011, 04:46 PM
  4. power plasma 50
    By cmd in forum Customer Testimonials
    Last Post: 09-15-2010, 02:52 AM
  5. power plasma 50
    By brucewelding in forum Everlast Plasma Cutters (PAC)
    Last Post: 03-06-2010, 01:04 AM
