I use gas lens all the time you can stick the tungsten out the size of the cup with no problems #4 out 1/4" @5LPM, #6 out 3/8" @ 6 LPM and when I stick it out more I put it up to 6LPM #4 out 3/8" and 7LPM with #6 out 5/8" to 3/4" for getting into tight spots and never had any problems on steel. One thing with electricity the bigger the gap the hotter the arc then the tungsten gets brighter with in reason pull away makes more heat keeping it closer will concentrate the heat to a small area and not be as bright. As Mark said also (Lifting the arc up off the metal will make the arc brighter)
Reason: ADD
