Results 1 to 9 of 9
Thread: Quick question regarding Powerplasma 50
  1. Default Quick question regarding Powerplasma 50
    Hi,
    I recently bought a PP50 and wondering if the fan is meant to run constantly?
    Not sure if I remember correctly but I thought when I first tried it out a few weeks ago, I'm sure the fan only came on after the first few cuts. I remember waiting around for the fan to stop before switching it off at the wall however it never did.
    Fan comes on and stays on as soon as I switch the machine on now, is this normal?
    Other than that it cuts like a champ !!!!
    P.S. Why didn't I buy a plasma years ago......
    The fan runs constantly on every Everlast machine that I know of. This gives a higher duty cycle.
    Mine also runs all the time on the pp50 & pa140 I have
    EverLast 140ST
    PowerPlasma 50
    No You Can't Use Them
    All fans are full time.
    Even Cubs fans?
    Ok cool. Good to know, must have just been my imagination, swore it was the fan starting up while I was cutting when I first tried it. Then again might have confused it with a distant air compressor starting.
    Quote Originally Posted by Rupes View Post
    Probably the compressor. If you scan the forum people complain about the fan on all the time and the noise, but better a working welder/cutter that way
    The fans on all my Everlast machines do run all the time, but I just have not figured out the system of high noise and lower noise fans the MTS250S is low noise fan and the 255EXT and 250EX is loud but it is to do with the duty cycle but the iMig 250 is loud and its duty cycle is the same as the MTS250S with a low noise fan.
    Even Cubs fans?
    Through thick and thin!!
    Powertig 250 EX
    Power plasma 80S
    Power cool W-300
    Lincoln 180 mig
    Ridgid chop saw
    20 ton press
  1. Quick gas question 255EXT
    By Gusman in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-17-2017, 12:09 AM
  2. Quick question about grounding a 250 ex
    By Blaze in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-21-2016, 11:17 PM
  3. quick question about gas flow
    By Hypnotk in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 12-28-2014, 07:50 PM
  4. Quick question, need some help?
    Last Post: 07-04-2012, 05:02 PM
  5. Quick question... 1" solid square..
    Last Post: 04-13-2012, 05:33 AM
