Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: how do you like your MTS250S and can you answer some questions
    Are you going to cut and etch it to check penetration ?
    this is the test piece cut with the saw.
Name:	spray weld steel100% argon.jpg
    Thank you for sharing. What thickness is the steel and how do you rate the penetration ?
    I wish we had more threads on spray transfer. Real world practical information is hard to come by on this subject.
    Yes, that is shallow...not as good as it should be with a mix...
    I spray transfer routinely. What would you like to know? There are several good slow mo videos online about it and a few good sites...if I could only find them again...lol.
    I'd like to learn all I can on the subject. I like to see others discuss real world application so that I may glean without being on the spot. Many people have never heard of spray transfer.
    I would add CO2. The depth is not the great. Marks like C18, but you need CO2 either way. We use Stargon or C25.
    It was 3/4" welded to 1 1/4" steel plate with no preheat or bevel cuts. I will try some mix gas I have 25% Co2 / 75% Argon in a small bottle.
    kempy, certainly not a 'sloppy' weld. As I've said, I'm not a steel guy but there is nothing inferior about a weld that has that kind of root penetration. Root penetration is root penetration. The AWS doesn't say much about it because it's not easily measurable like the leg or face of a weld.
    AWS D14.3-94, paragraph 2.3.1.1, reads as follows:“Design values based on depth of penetration or effective throat, or both, which are beyond the root of the joint shall only be used when the values have been determined from a significant number of cross-sectioned samples which reflect the range of materials, material thickness, and welding conditions.”
    Imagine a spec'd 1" fillet weld - it wouldn't have any more 'root penetration' because that would be accomplished on the first pass at the root!
    Of course, it is a 'good thing' to have adequate root penetration but not in the sacrifice of other things.
    Here is your weld that I drew over because the outline of the weld is fairly easy to see:
Name:	kempysweld (Medium).jpg
    YOU'RE HIRED! Nothing wrong with this weld! Everyone has a way of getting to an end. Obviously, you made a nice appearing and sound weld. You learned from the experience, that's something to build on and expand. Listening to people tell you 'the best way' to do things is in the end, limiting.
    Yofish,
    Keep in mind, the point is to improve what is going on with trustworthy and accurate AND proven information not your subjective and a verifiable inaccurate opinion. Spreading false information and trying to portray yourself as an expert is a good way to get placed in time out. Final warning.
    You also need to learn to read what was said more accurately. I didn't say the weld was sloppy. I said when you spray weld with 100% Argon, the puddle is sloppy wet compared to a proper Argon mix designed for spray welding. This makes the weld uncontrollable and by comparison a shallow penetrating weld compared to standard spray. It makes a wider, more shallow weld. As one who makes spray welds on steel routinely and one not only has received informal and formal training in the process, I know the difference and have seen the difference trying not only pure argon, 75/25, 98/2, 90/10 and my favorite C/18. Due to the type of welding I do, about 75% of the time I am using a true spray transfer process.
    75/25 is NOT a true spray process. The voltage required to ionize the gas to create spray is too high and then you get issues. You can get a globular transfer, and/or a very uncontrollable spray that inconsistent and overly hot by comparison which creates a larger HAZ. People think it is spray until they use a real mix designed for it. The difference is significant.
    finally some sanity. a lot of pseudo science here. not like you can't just google spray transfer and get answers from REAL experts.
    going to buy me a ticket to Alaska LOL. this guy couldn't buy me a bus ticket to the airport.
    http://www.amazon.com/Black-Decker-7...R1KPJ0QBSJQ7KC
    i needed a cheap grinder and look who i see.
    he's on boatdesign.net pumping the software. in a 2014 poll he's the only vote for it is his. lol
    can't be bothered with the link
    why do they gravitate here? are they on the longevity site also?
    Like I said, put up or shut up.......
  12. #32
    Test different gases. Used MTS250S in Mig mode not SYN/Mode all welds done with the steel cold using 98% Argon 2% o2 and 75% Argon 25% Co2 and 100% Argon. The eases to weld was the 2% o2 and 98% Argon all welds same settings except the Short circuit weld. The Spray Arc set to 25.5 Volts gas flow 12 LPM.
Name:	spray steel four welds.jpg
ID:	12013Click image for larger version.
Name:	spray steel three welds.jpg
  13. #33
    The 75/25 showed the best penetration, but it is too much CO2 for proper spray. A little less and you won't see much difference in penetration but a lot smoother easier flow. The 98/2 even showed better penetration at the toes than pure argon. That's where a 90/10 or a 85/15 or even 82/18 (C18) would help out...and give better penetration with lower settings. The short arc is pitiful, but the lack of fusion is a result of making one heavy thick, gobby pass. This lesson can be carried over to aluminum as well by the way, not in the gas mix, but in the penetration and fusing at the root and at the toes...(short circuit versus spray)
  14. #34
    Mark when I get the tank down to 2000 psig I will add 100% Argon and it will drop the Co2 down, I will calculate with my program to get the Co2 to 18% then and later to go to 15% then down to 10% Co2.
    Sorry to be out of action on my own thread. I have been working 16 days straight. This is the first chance I have had to be on line. Kempy has answered the spray transfer question . Does anyone know about how well it welds 7018 rod and 6010 rod? I will be buying one either way but it would be nice to not have to have a separate machine to stick weld with.( I always have my Miller 302 with me but I use customer power most of the time and do not want to fire up the 302 if I do not have to.)
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    Well I was going to start a new thread but the thread starter button does not work So Im going to ask the question here. I have been on this site for about 7 or 8 months and still confused. There have been statements made about an industrial line of welder and the ones sold on this web site. So I guess I would like to know if the welders sold on this site are for industrial use or not. Are they of equivalent quality to miller dynasty welders and sutch or not. There have been comments about needing 50K to get an industrial catalog. I have been using and buying welders most of my adult life and have never heard of sutch a thing. For instance miller sells bobcat line of gas drives but also sell trailblazer line and others but they are all available to anyone. I want to compare apples to apples. Not compare a hobby welder to a welder designed for daily use in industrial use.
    millermatic 200 mig
    2016 Everlast 250EX
    miller tig cooler
  17. #37
    Gary,
    You have to decide for yourself based off your use habits etc, whether something is industrial or not. Miller rates everything as commercial/industrial nearly, though many units would not be considered as such. We have a couple basic "industrial" units already on our site. We're talking about day in, day out, 12 hour shift work, near max capacity production work. They are the MTS 400, the PP 100, and the PowerTIG 315lx the PowerTIG 325EXT etc.
    When we discuss industrial, we are talking about units that retail usually over 3k and up to 8 k for the basic units. We are also talking about units that are 3 phase only with heavy potted boards etc different designs etc.
    Many people use our product in professional settings. It's a name that refers to it's capability and level of use. There are other names such as commercial, industrial, and now Mr. TIG is throwing around a self created name called "Utility". He and I have had a talk about it. His videos try to portray the Everlast line as a lower, utility class level for homeowners. Well, that' simply not true and he has made up the word "utility" to describe our welders, much to the dismay and disagreement of several within the ranks. But I would not say that a Everlast Power iMIG 140E is a industrial unit, though many professionals may use it in a muffler shop or some light repair facility. But Miller would call this unit somewhere between light industrial to industrial..... http://www.millerwelds.com/products/...e/basics6.html
    Duty cycle, amps, and power input in my mind decide what "industrial" is. We produce our industrial line in smaller qty lots, and have orders for them before they are shipped...with the exception of the smaller, more widely demanded items. When I say 50k....that is in part a minimum order qty that we need to meet to produce the product. That's why we sell these direct to larger companies and organizations, many overseas on pipelines in the middle east, oil derricks etc all over the world. Price wise for us here in the US it is hard enough to sell excellent products like the MTS 400 because the price is rising above the average consumer who is interested in our product here in the US.
    We have full synergic digital double pulse 600 amp MIG units with exhaustive parameter setups and even power bank welders that we can and do manufacture if it is right. And these units are in a whole different class. IF you want to get a sample and taste, get the MTS 400. On 240V 1 phase operation, it is limited to 250 amps, but it's 100% duty cycle too at that level.
    Here's the sample out of one of our catalogs of our analog and industrial line of MIG/Multiprocess welders that I am referring to...up to 630 amps. Note that the E MTS 400 is the one we sell here simply as the MTS 400. The other smaller MIGs are different design than what we sell, and are typically more expensive than the ones we sell here...which puts them above the equivalent Miller transformer welders...which makes it a moot point to sell them here in the US but not elsewhere if requested.
Name:	Industrial Models-1.jpg
ID:	12043   Click image for larger version.
Name:	pic industrial.jpg
  18. Default
    Thanks for clearing that up Mark. I guess I always go by duty cycle. To me if a machine is rated at 60% duty cycle it is industrial. I know many new migs are rated at 35% like the mts250s. I have a millermatic 200 I purchased new in the 80s it is rated at 200 amps 60%. The new miller 252 is its newer equivalent as far as duty cycle and output go. So in my mind the MTS250S is a 200 amp industrial model even though it is rated at 250 amps. If my comparison is incorrect let me know. I will be using it in a light industrial capacity but I do not want to have to replace it every couple years. In my mind if a machine is kept below its duty cycle it should last for many years. Like my MM200, I have no intention of replacing it since it does such a good job . My expectation of the MTS250S is going to be compared against my MM200 since their duty cycles and output are very close to each other.
    millermatic 200 mig
    2016 Everlast 250EX
    miller tig cooler
  19. #39
    The 250S also only has an 8" roll capacity currently
  20. Default
    I can live with the 8 in roll since I want it to be portable. I really do not need all the bells and whistles the 250s has. Actually a machine like the Imig 205 would do me fine but I need the 250 amps of the 250s.
    millermatic 200 mig
    2016 Everlast 250EX
    miller tig cooler
  1. 30A fitted to MTS250S
    Last Post: 07-12-2014, 02:21 PM
  2. MTS250S job SST table for potato peeler
    By Kempy in forum Welding Repairs
    Last Post: 04-20-2014, 10:21 PM
  3. Mig 25 Torch MTS250S
    Last Post: 03-28-2014, 12:39 AM
  4. MTS250S weld Genie on job site
    Last Post: 12-11-2013, 08:40 PM
  5. MTS250S Code 802 ??
    Last Post: 07-29-2013, 01:31 AM
