Results 1 to 3 of 3
Thread: Foot pedal question
  1. Default Foot pedal question
    Just making sure machine is working as intended. PowerUltra205P - panel switch is set to "pedal". Depressing pedal, then releasing it, amps will go from approx 5 to 200, then back to 5. Panel switch set to "panel". Amp control knob set approx 1/2 way. Depressing foot pedal, then releasing it, it will only go to amps set by knob, but no gradual ramp up then down, just acts as on/off switch. Is this correct operation? Thanks
    That is correct. The panel is for the torch switch...and all you are doing is turning power on or off. Have you read the manual? http://www.everlastgenerators.com/do...eries_2013.pdf
    Thanks. Was hoping it would act like a limiter, with up/down ramp, but at least I know it is working as intended.
  1. PA 160STH with foot pedal question
    By bnorth in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 09-10-2015, 10:00 AM
  2. Miller foot pedal question
    By bswinn in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-25-2014, 11:40 PM
  3. a foot pedal question about the power tig 185
    By robmillion in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-17-2013, 02:44 AM
  4. Foot pedal question
    By Brian Ski in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-12-2012, 06:33 PM
  5. foot pedal question?
    Last Post: 07-11-2012, 03:26 PM
