Results 1 to 3 of 3
Thread: The 'Best" TIG, who has what and why?
  1. Question The 'Best" TIG, who has what and why?
    I have a small machine/Tool and Die shop and need to get an AC TIG that's capable of welding 'anything'.
    I know that I too have to be capable and have a lot to learn having only had a cheap 200 amp DC TIG. The problem is that literally anything can come through the door from 28 gauge aluminum to 2" steel plate and while I understand that a welding shop is better for the larger jobs, and I do farm those out now, it would be great to be able to keep the smaller ones in house. I have Power IMIG250P that covers most of the steel parts that can be MIG welded but the nonferrous and stainless is the issue.
    Go with the PowerTig 255ext and be done with it!!
    One hell of a machine!!!!
    From the desk of Kevin Caron, where the answers are stranger than the questions....
    www.kevincaron.com
    Nova Scotia, Canada
    No argument there.
    AC/DC inverter TIG can weld whatever is weldable. It's not the fastest, but it is the most versatile. The stick function makes up the rest for things like welding cast iron or working with dirty metal.
    A few thoughts for the machine shop: if you want to repair large (heavy section) aluminium mis-machined parts, lots of amps is great to have. Pulsed is handy for building up thin sections or outside edges without undercutting. It's also perfect for doing weird stuff like tonight I was welding all these 1/8" rods to the edge of 16gauge stainless without undercut. I can't really comment on thin aluminium, but I would imagine low starting amps would be critical for that, which I understand the 255ext excels at. I have an old 225LX (like the 250EX) which starts a little higher. Steel and to a larger degree stainless doesn't need many amps since you end up in multiple passes for anything really thick. I don't go over 130 very often.
    Foot pedal is preferred by most for sit-down jobs, but personally I've moved away from it to the trigger for almost everything I do.
  1. Everlast Super200P died. Performed "diode-ectomy". Now it's welding again!
    Last Post: 01-27-2015, 09:24 PM
  2. Northern Industrial 1644910 AD Helmet Opinions? (3.82" x 2.44" view area)
    Last Post: 01-10-2013, 03:49 PM
  3. Replies: 11
    Last Post: 10-30-2012, 06:43 PM
  4. Cutting 3"x3"x3/16" Angle
    Last Post: 07-01-2011, 11:56 PM
