Im having a problem of not having any amperage control using the foot pedal on tig. Its either idle or straight to the set amps when you move the pedal the slightest amount. Ac or dc, it dont matter. The pedal an ssc control with the 50k pot. Machine is set to 2t, start/end apms at minimum, up/down slope at minimum aswell. Whats sucks is i sent the machine in for warranty where they had it for 4 months and its still not fixed. Theyre claiming its a pedal but the pedal ohms out at pin 3-4 is .9-48.1k and pin 4-5 is 48.1-.9 ohms. So its well within the +/-10% they say is acceptable. Any suggestions on what to do. Any help is appreciated
