Thread: Welding aluminum with 255EXT
    Default Welding aluminum with 255EXT
    Weld 2"3/8 pipe to 2"3/8 pipe 255EXT almost wide open running at 230 to 250 amps know problem, was easy. Then prototype car parts made of steel and aluminum I have many parts to do in the next few months will post on this thread.
Name:	pipe to pipe .375 wall 1.jpg
ID:	12089Click image for larger version.
Name:	pipe to pipe .375 wall.jpg
ID:	12090Click image for larger version.
ID:	12091Click image for larger version.
Name:	steering box holder 1.jpg
ID:	12092Click image for larger version.
Name:	steering box holder.jpg
ID:	12093Click image for larger version.
Name:	valve cover breather 1.jpg
ID:	12094Click image for larger version.
Name:	valve cover breather 2.jpg
    Did you use any pulse or raw power?
    Mark
    Just straight power for the Aluminum on Advance Square Wave no pulse, 35% clean, AC Frequency 250 Hz, 100% Argon @ 28 CFH and 2% Lanthanated 1/8. Steel no pulse, 100% Argon @ 12 CFH and 2% Lanthanated 1/8 also. I like the preset Memory Program just switch to the number I have set for steel and weld or just got to the aluminum number preset and go. I wish they had more memory number, I set them close to what I like and adjust after take a little more time but it is still faster then my 250EX. I still like my 250EX I put the smaller torch on it so I don't have to keep change Tig guns.
    More welded parts of Prototype car using PowerTig 255EXT.
Name:	All parts.jpg
ID:	12149Click image for larger version.
ID:	12150Click image for larger version.
Name:	Bracket and jig 2.jpg
ID:	12151Click image for larger version.
Name:	Bracket and jig.jpg
ID:	12152Click image for larger version.
ID:	12153Click image for larger version.
Name:	Brackets back welded.jpg
ID:	12154Click image for larger version.
Name:	Brackets before welding A.jpg
ID:	12155Click image for larger version.
Name:	Brackets before welding.jpg
ID:	12156Click image for larger version.
Name:	Brackets inside welded.jpg
  1. 255EXT Aluminum Tig Pulse Settiing Comparison/Suggestion
    By travis1693 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-25-2018, 02:40 AM
  2. 255EXT Pulse Stick Welding
    By Marmoset in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-12-2017, 09:08 AM
  3. PowerTig 255EXT welding power problem
    Last Post: 02-18-2014, 10:56 PM
  4. Welding Airboat -18C outside with 255EXT
    By Kempy in forum Welding Repairs
    Last Post: 01-28-2014, 11:52 PM
  5. Replies: 2
