Thread: Power Tig 200DX Dual Voltage Maintenance
    Default Power Tig 200DX Dual Voltage Maintenance
    Hello Mark,
    I've had my machine now for nine months, and it has performed flawlessly. I want to remove the cover and blow any dust out with compressed air as per the "care and maintenance" section of my manual. There is no diagram. Are there any precautions I need to take before removing the cover? I don't want to do anything to void my warranty, should I ever need it.
    Thanks in advance Mark,
    MagicHat
    Quote Originally Posted by magichat View Post
    Hello Mark,
    MagicHat
    Just pull the cover starting from the rear. No need to remove any front panel screws. Blow it out with dry compressed air being careful of any circuit boards and that's it. Don't over tighten the side screws.
    Unplug the unit for 15 minutes before you start. As Zoama said, remove rear panel first (don't need to clear power cord though), and then remove the metal cover. Try to spread the bottom of the metal cover and inch or two when pulling it up and to the rear at the same time. I'd personally cut the air pressure down to blow it out and wear eye protection. Check the fan blades for any metallic build up from grinding/welding activities, carefully scrape/knock it off if possible.
    Thank you Zoama and Mark! I was hoping I didn't need to remove the front panel. I appreciate the advice and quick reply. I'm very happy with my 200DX.
    MagicHat
    Took about 15 minutes as per your instructions. Hardly any debris or dust was found. I don't do any grinding around my machine though. Thanks again to Mark and Zoama. I've gone through about 25 tanks of argon (125's) so far with no problems of any kind.
    MagicHat
    MagicHat
    That is a lot of tanks. What type work do you do?
  1. PowerTIG 200DX Dual Voltage Gas Inlet Fitting Size
    By MBfrontier in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-26-2014, 11:42 PM
  2. confused about 200DV and 200DX dual voltage
    By FlorinAndrei in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-24-2014, 05:02 AM
  3. HF Start Points Adjustment on Powertig 200DX Dual Voltage
    Last Post: 02-25-2014, 02:03 PM
  4. Just received Dual Voltage 200DX TIG Welder
    Last Post: 10-28-2013, 12:41 PM
  5. 2013 Powertig 200DX 200 Amp 110/220 Dual Voltage Pulse AC/DC
    Last Post: 09-23-2013, 05:22 PM
