Wiring
![Quote](images/misc/quote_icon.png)
Originally Posted by
Ron66
I've been meaning to ask this for a while now. First let me explain my setup. On the far wall of my garage I have my 240V outlet which s about 1ft away from the breaker panel. My work area is on the other end of my 3 car garage so to get power to the welder I use a 6ga 30ft RV extension cable. The outlet is a 4 prong outlet with Phase 1, Phase 2, Neutral, and ground. The RV extension cable is the same. The welder has a four prong plug on it now but the earth ground lead is not plugged in.
Now the issue. If everything is plugged in and I flip the switch on the back of the welder the breaker in the panel trips. If I first turn on the switch and plug the welder into the RV extension cable the breaker in the panel trips. If I first turn on the welder and plug the RV extension cable into the outlet there is a little bit of flash arcing but everything is fine.
Anyone run into this before? Ideas?
Your RV plug is for 120 volts only if you have a 4 wire RV plug it is still 120 volts, unless you have changed some things.Most 4 prong RV twist lock connectors are marine connectors which have an extra neutral or ground. These are used and added to RVS for various reasons including stopping red ants from following the cord into the camper.
Please remember RV cords and plugs are for 120 volts operation, I have repaired many blown RV power systems because someone plugged there RV into a welder outlet.
Your 50 amp plug on your welder has 3 prongs 2-120 prongs when combined give you 240 volts and one half round prong center top which is the ground.
Yes there is voltage present in the ground or neutral wire when you machine or whatever is plugged in and operating. Electricity must have a ground to work.
To make your breaker trip 2 things need to happen overheating from to much power draw or a short in the circuit in your wiring a sudden trip is a short slow is overheating , thus more than likely your wiring is crossed somewhere causing the trip..
PowerTig 200DX
Supercut 50P
Millermatic 200
Jet 1340 Lathe
Jet 20" Drill Press
Jet 12" Wet Band Saw
Kalamazoo H7 Bandsaw
Forward 12,000 lb 4 Post Lift
