Results 1 to 4 of 4
Thread: Gas info
  1. Default Gas info
    My Powertig 250 ex manual states only pure argon or argon helium mix. No co2. My I mig 250 states 75/25 for steel. No pure Argon for steel with the Mig. Does this also mean that pure argon for the Tig for steel would be wrong? I plan on purchasing pure argon to weld aluminum with both machines. However I am hoping I don't need to buy 75/25 for the Mig and argon/helium mix for the Tig to weld steel. That would be 3 different gases and I'm trying to save money and only use two gases if possible. All help appreciated!
    Everlast PowerTig 250EX w/ PowerCool W300
    Everlast PowerMig 275S
    Everlast PowerPlasma 60S
    Use straight argon for tig welding, alum, steel, stainless. Use straight argon to mig aluminum, use 75/25 to mig steel. You can use helium or mix with argon to weld alum. if you need more heat but it usually is not needed.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    Quote Originally Posted by Blaze View Post
    I think you misunderstood. You need 75/25 to mig steel.
    You need 100% argon to mig aluminum... or to tig weld most metals.
    One bottle of 75/25 and one bottle of 100% argon is all you need.
    Thank you fellas! New guy trying to set up my little shop! I finally got power!
  1. Electrical info needed
    By Blaze in forum General Welder Questions
    Last Post: 03-23-2014, 07:25 PM
  2. tig info
    By dennis in forum General Welding Questions
    Last Post: 02-11-2012, 08:30 PM
  3. need return info
    By dennis in forum Pre-sales, Sales and Shipping questions
    Last Post: 12-31-2011, 05:20 PM
