Results 1 to 20 of 35
Thread: New 2015 PowerTIG 255EXT
    Default New 2015 PowerTIG 255EXT
    We're almost ready to release the 2015 line for the fall. The new PowerTIG 255EXT is on it's way soon. I think this years model has about everything that we could practically put into it and incorporates many common customer requests.
    This year we've added a few pleasant features to it.
    This years model includes the following new features:
    1) 120V/240V 1 phase capability. Yes, that's right. It's slated for UP to 150 amps on 110V. The three phase has been deleted in favor of dual voltage and the 325EXT will be the 240 1 phase/3phase 480 3 phase capable unit now.
    2) We've added a spot weld timer for unit so that it has similar capability to the 250EX in that regard
    3) We've added purge control so that adjusting regulator settings is not so hard
    4) The new E6010 setting will help improve performance when welding with E6010/6011 rods.
    It uses the same case and a few controls have been rearranged but it's parameters are largely unchanged. It's been refined into a more versatile unit without messing with what makes the unit a great unit to have.
    I see the PFC is not on the new 2015 255EXT is it removed or is it not the final face plate? The new features look good.
    Kempy
    there is no room for PFC logo
    Oleg Gladshteyn
    Will the 325EXT also get the spot timer and E6010 settings?
    It hasn't been put forth yet.
    Mark as you put it (I think this years model has about everything that we could practically put into it and incorporates many common customer requests.)
    This customer is requesting if the two select buttons could go both ways so you don't have to go thru all the selection to get back to the one you just missed. The Gas Purge button is very nice idea.
    No. We've discussed this and think as it is there is just no more room to get things in. Factory feels that it just isn't doable...and I tend to agree. It is a little inconvenient, but still works fine as it does not cause a great delay in setup usually.
    While I understand the need for PFC on a transformer machine why is it required on these inverters? 60 amps doesn't seem like that much for an input circuit especially when you consider the "welder only" derate by NEC code for the wiring.
    Quote Originally Posted by Datsun1973 View Post
    One big reason is running from a generator. Plus the fact that it's always nice to have balanced loads.
    More innovation... wow!
    Wow I havnt been on in awhile but I love my origional 255EXT.. I would love to have had it dual phase like the new ones. I didn't think it could get any better..
    As to the reverse direction, I would argue the ability of it but really I agree that its not worth the effort to try and incorporate. I have never had an issue with it only going in one direction. Purge button is a good idea and I have mentioned out load to a friend I wish mine had one but really I just tap the pedal and it is not really hard at all to set.
    The unit you have is dual phase, but it is not dual voltage. The new ones are no longer dual phase, but dual voltage.
    Mark
    Are you saying they are single phase dual voltage or three phase dual voltage?
    New units are single phase 120/240V...only.
    Mark
    At 120V that makes that a very portable machine and that would go nice with the new water cooler that is 120/240V also.
    Yes. The unit itself will produce 150 amps TIG and 120 amps stick on 120V.
    Jun 2014
    Ontario, Canada
    Any idea on a release date yet?
    *Edit* NVM Checked the US site and it's there, Guess I'll have to bug the Canadian guys to get it.
    Jun 2014
    Ontario, Canada
    What's the recommend circuit amp rating for running at 110v? Would 15amp be enough?
    Quote Originally Posted by Seshan View Post
    30A for full power operation. Depending on how much power you need, you might get by with 15-20 at a reduced output level.
    Released. Qty's limited though.
  1. PowerTIG 210EXT 2015 Model Question
    By Baronsbest in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 05-26-2016, 05:08 PM
  2. 2015 Powertig 185 - Foot pedal pot size clarification
    By tiganis in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-28-2016, 06:34 AM
  3. Struggling with low current starts on 255EXT 2015
    By windscreen in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-12-2015, 05:06 AM
  4. 2015 PowerTIG 210 EXT: Review, Rationale, 1st Project
    By christian in forum Customer Testimonials
    Last Post: 07-01-2015, 10:20 PM
  5. PowerTig 255EXT got CODE 805
    Last Post: 12-08-2013, 08:33 PM
