Results 1 to 12 of 12
Thread: IMig 140 Power Supply
    Quote Originally Posted by ChuckD View Post
    Hello All,
    I purchased a iMig 140 to use for simple jobs around the house. I decided to have a dedicated circuit for the welder. The breaker in the box is a 30 amp. When I plug the welder to a regular 15 amp circuit and set it up for an 1/8 plate using 0.30 wire and a 25/75 mix I can get it dialed in, but the weld is a little cold. If i keep the same settings and plug it into the dedicated 30 amp circuit it burns to hot and almost burns through. The question I have is shouldn't the welder draw only what is necessary for the settings? My gut feeling is maybe the dedicated circuit being only 6 feet from the breaker box has a increased voltage. Any advise would be appreciated.
    Thanks,
    Chuck
    Boise, Idaho
    Chuck, the unit will only pull what it needs from the panel settings. So how close to the breakers will not cause a problem. If you vary the volts, do you see a change in the power?
    Mike,
    I do see a change in power when I vary the volts. Plugged into a 15 amp circuit the tuning was sluggish, but plugged into the 30 amp circuit it is quite sensitive to slight changes and feels like it has a 1/3 more power. I like having the ability to apply more heat when needed, but wouldn't think that just plugging the unit into a different circuit would make that much of a change.
    Chuck
  1. Power iMIG 275P Wire Feeder Alignment Question
    By Baronsbest in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 05-22-2016, 05:01 PM
  2. MIG starter supply suggestions?
    By redbeard in forum General Welding Questions
    Last Post: 06-20-2013, 10:09 AM
  3. Power I-IMIG 250P questions
    By Diabolical in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 02-13-2012, 09:05 PM
  4. power IMIG 205
    By Wrenchtamer in forum Customer Testimonials
    Last Post: 03-04-2011, 12:47 AM
