Page 1 of 3 123 LastLast
Results 1 to 20 of 58
Thread: Flux Core?
    Aug 2014
    Default Flux Core?
    Hi all. I am trying to weld 16 gauge square tube to a 1/4" plate. And seem to have trouble getting a good looking bead. I am using .030 Hobart FC. And an I Mig 140E. I am having trouble finding the correct V and Wire feed. Comes out clumpy.
    Elantramax1
    Correct voltage and wire speed? Have you made sure you have the correct polarity? And are using the correct Flux core drive rolls?
    Aug 2014
    I have th F Drive Roller. Torch- Neg, Clamp-Pos
    Well, check the groove and make sure it is the right size and make sure it is not riding on top of the roller and is fully in the groove. Check the drive tension, and check the spool tension and make sure it isn't hanging or is really tight. The roll shouldn't coast but it should stop dead either. Which drive roll combination of sizes did you get? I can't recall right off my head which sizes that are available for it, but if the groove is too large or small, it could be an issue. .8 is .030".
    One of the other possibilities is that you aren't making a good work clamp connection. The work clamp should be attached directly to the metal. Do not run it through the table for best results. Or, it could be the work clamp itself isn't making good connection.
    Addditionally, check out the information here. It has all the specifications for your particular type wire. It gives amps and volts for running it in the pdf info on each product....Don't know what to suggest because we don't know the specific wire you have. http://www.hobartbrothers.com/produc...-shielded.html
    Elantramax1
    Pictures always help.
    Aug 2014
ID:	12354Click image for larger version.
    Hobart E71T-11 .030
    This stuff is really Smokey. I grinded it down a bit. If I run the V at #4 sometimes it seems to blow through. Turned it down a bit to fill in.
    Is the wire feeding smoothly into the puddle or does it pop, skip, stub ? How close do you keep the tip to the puddle ? Are you grounding to bare metal ?
    For the kind of stuff you are building, I think you would be a lot happier with solid wire MIG and C25 instead of flux core.
    Aug 2014
    I am grounding to bare metal. Cant really see the puddle. A little bit of popping.
    Aug 2014
    Right now I don't have a cart. And the price of the Tank is out of my budget. I do know it would give me better looking welds.
    Aug 2014
    Could part of my problem be the Mill Scale? That black coating that comes on the metal. The metal was labeled "Plain Steel".
    Elantramax1
    Ok, so yes...mill scale will be an issue. But the smoking and popping is part of flux core. From the looks of it, a lot of it is technique. You should be holding about 1/2" worth of stickout. That's the distance between the puddle and the contact tip. Too long of a stick out will cause some of the issues you are seeing. It should help reduce the popping too. But if you are getting a lot of it, your wire speed is too high.
    You need to correct that. You might need to try a different shade depending on your vision. The usual starting point for what you are doing is #10, but you might do better with a #9 or #11. Also with flux core or stick welding, you will periodically need to clean or replace your cover glass, as it gets covered with smoke debris and spatter.
    Start by leaning over in front of the direction of travel while keeping the torch in place and looking at the front of the puddle as you weld. That may seem strange but is a standard part of welding.
    Aug 2014
    I have a Hobart Impact series. Set on #9. And I do clean the outer lenses afterwards.
    Stick out I was always told was about 3/8" Which is hard to do on an inside joint. I am going to check my Contact Tip for wear. Not sure how many feet before they need replacement.
    I saw a 20 CF tank at Tractor Supply. It may be big enough for what I do??
    Aug 2014
    I should be leaning over the tip? I've been doing an off to the side from behind the torch.
    The puddle isn't behind the torch, it's in front.
    Aug 2014
ID:	12360Click image for larger version.
    How does this look?
    As far as the spatter and smoke go, pretty much normal. The bead looks like it needs more voltage and wire speed possibly.
    Flux core really isn't for thin metal. It's not delicate enough and will burn through before MIG. 20cfh is not enough for the average hobbbyists. That's less than an hour worth of use. For me I wouldn't consider anything less than 125.
  1. HF Flux Core?
    By Elantramax1 in forum General Welding Questions
    Last Post: 10-27-2014, 09:07 PM
  2. Welding with flux core wire
    By Chris A in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 06-08-2014, 05:20 AM
  3. Imig200 flux core welding questions
    By sw2x in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 03-30-2013, 10:24 AM
  4. IMIG-200 with flux core, running on generator
    By chadford in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 10-08-2011, 10:04 PM
  5. Gas vs flux core
    By MigPlazArc in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 10-06-2011, 03:11 AM
