Results 1 to 14 of 14
Thread: Cummins exhaust manifold cut to fit
    Default Cummins exhaust manifold cut to fit
    Cut this down to fit my 4bt cummins and tig welded with my 210ext Click image for larger version.
ID:	12491Click image for larger version.
ID:	12492Click image for larger version.
    LONGEVITY 250EX Tig
    MILLER 211 mig w/spool gun
    SMITHY 1324 mill/lathe
    60 gal. 7.5 hp air compressor
    Just curious, how did you cut it, and did you have flush mating surfaces or did you have a gap? I've always heard that for cast iron you have to preheat and post heat carefully to avoid cracking. Same deal for you?
    I left a small gap chamfered both sides, cut it with a band saw and I did pre heat it and clamped it to the table till cooled to ambient temps
    LONGEVITY 250EX Tig
    Very nice work. May we see the whole project ? I'm thinking about putting a 4bt in a ranger.
    Yes sir! As it unfolds:-) the 4bt will be going in a 2000 jeep tj sport all parts (minus trans adapter) will be built in house and documented. Stay tuned for more.
    also being built in house will be a long arm susension using ballistic fabrication coil over shocks
    LONGEVITY 250EX Tig
    What filler metal did you use on the exhaust manifold ?
    Er70s-2 seemed to work fine, no cracking occured
    LONGEVITY 250EX Tig
    A little more progress, reshaping the ports
ID:	12494   Click image for larger version.
    LONGEVITY 250EX Tig
    Why did you choose this exhaust manifold and how much power do you plan to make ?
    Quote Originally Posted by dzljon View Post
    We use it a lot without any issues. We have 316 (TIG) and 308 (MIG), but rarely use it.
    I chose this manifold because I already had it and no body I know if has tried it so it made for an easy choice I am looking to get 175 hp 370 tq that should be plenty but I an going to compound this with a hx30 in the future
    LONGEVITY 250EX Tig
    That amount of power should be fairly easy to get with a 4 BT. If you have an inline pump it will be very easy, with a rotary pump it will be a little harder but not much. a 3000 rpm ask a set of 4 215 injectors from a 6 BT , a larger exhaust ,an BHAF and you would be there.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    Here is the manifold and turbo bolted in placeClick image for larger version.
ID:	12546Click image for larger version.
ID:	12547Click image for larger version.
ID:	12548Click image for larger version.
ID:	12549Click image for larger version.
    LONGEVITY 250EX Tig
    The oil filter will be remote mounted
    LONGEVITY 250EX Tig
  1. Cummins turbo mount
    Last Post: 10-28-2017, 08:03 PM
  2. 4bt Cummins motor mounts
    By dzljon in forum Other Custom Fabrications
    Last Post: 08-31-2016, 07:14 AM
  3. Cast manifold repair
    Last Post: 12-14-2014, 02:34 AM
  4. 1936 Ford Schoolbus with Cummins 5.9 NV4500
    By Tacoma747 in forum On Road Fabrication
    Last Post: 08-20-2013, 09:27 PM
  5. Replies: 0
    Last Post: 04-29-2011, 06:41 AM
