Results 1 to 3 of 3
Thread: Torchmate AVHC with PP60s
  1. Default Torchmate AVHC with PP60s
    Ok so after having my cnc set up for a little over a year ive decided to go ahead and buy the TM AVHC. i am upgrading from a 2x2 to a 4x4 table in the next 2 months so my controller wiring/ positioning is just temporary but all my connections are good.
    So i went ahead and set up my pierce height, cut height, and all other settings for the 10g steel i was about to do a line speed test on. i had the plasma cutter set at 40 amps and the speeds went from 40-130 IPM. i did the line speed test in manual mode ( so the torch stays in the cut height that was set and doesnt make changes to warped plate ) which is what is required for this simple test. everything went pretty good.
    Moving on to the Voltage Test is where im having my issues. when i did my voltage test my Current Voltage reading on my AVHC Controller was only reading 20-24V. i tried changing amperage, cut speed, and cut height with no difference. so then i decide to try and cut a small browning logo in Automatic mode and after about 2 seconds of cutting the torch starts retracting, i believe its looking for more voltage and thats why its doing that, hense the very small Voltage reading on the control box.
    i cant seem to figure out why im getting such an unrealistic number on my Current Voltage reading. My AVHC Controller will not let me Set my voltage any lower than 50V which is what i presume the bare minimum that the Plasma Cutter should be.
    Please Help!
    what pins should be wired for raw voltage on the cnc plug at the back of the plasma cutter. its a torchmate unit.
    After plowing through forums on Pirate4x4 i found one guy that used a everlast system with AVHC, it seems as though the raw voltage pin on the plug is not actually raw voltage, he had to hard wire it into the plasma cutter itself directly to the ground cable and positive. i guess ill have to call everlast tech and see what they recommend for this.
  1. Traffimet S75 on PP60S - Questions
    By Macdaddy in forum Everlast Plasma Cutters (PAC)
    Last Post: 03-26-2018, 10:03 PM
  2. New mud rims with my pp60s
    By drthunder33 in forum Welding Projects and Pictures
    Last Post: 06-12-2015, 06:57 PM
  3. PP 80s on a torchmate
    By dzljon in forum Everlast Plasma Cutters (PAC)
    Last Post: 12-29-2014, 05:27 PM
  4. Plasma & Torchmate
    By worntorn in forum Everlast Plasma Cutters (PAC)
    Last Post: 07-05-2011, 02:52 AM
  5. Power Plasma 50 & Torchmate 2 x2
    By geezer in forum Everlast Plasma Cutters (PAC)
    Last Post: 08-08-2010, 04:47 PM
