Results 1 to 5 of 5
Thread: My tig pedal stopped working is there a warranty on this part from everlast?
  1. Default My tig pedal stopped working is there a warranty on this part from everlast?
    So I was welding the other day and all of a sudden my pedal no longer triggered the welder u plugged and unplugged connections, still I had no luck. I decided to plug in the torch trigger and the welder ramped up so I'm sure the issue is in the pedal somewhere. My welder is two years old almost since I got it new. Is this an item that will be covered?
    I believe accessories have a six month warranty from the date of purchase.
    That is correct. All accessories have a 6 month warranty.
    What would be a good pedal to get that isn't to expensive I have a power pro 256
    Quote Originally Posted by fullydrooped View Post
    The replacement Everlast model is the low price option, the SSC is the better quality option, but the pedal is a pretty simple device, I'm sure you can fix yours for peanuts. It might be a simple mechanical problem, or if it is electrical, it sounds like either the switch part has gone bad, or perhaps a broken wire. A quick check with an ohm meter and you can sort it out in no time. You might as well take it apart and have a look before deciding.
  1. 200dx pedal stopped working properly
    By deathguppie in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-06-2015, 05:28 PM
  2. Plasma on my PP256 stopped working
    By DeeEmm in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 07-08-2014, 01:18 PM
  3. PowerTig 225LX Foot Pedal stopped working, How to Ohm Test?
    Last Post: 12-18-2012, 07:40 AM
  4. Pedal stopped working PP256
    By Timberwolf in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 06-08-2011, 05:42 AM
  5. my 250 EX stopped working
    By Rodsmachineshop in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 03-06-2010, 07:00 AM
