Results 1 to 7 of 7
Thread: Project: fuel cell(pics)
    Default Project: fuel cell(pics)
    Local guy needs a custom fuel cell for a hot rod he is building, so I started Saturday and this what I have so far
ID:	12535   Click image for larger version.
ID:	12536   Click image for larger version.
ID:	12537   Click image for larger version.
ID:	12538   Click image for larger version.
    LONGEVITY 250EX Tig
    MILLER 211 mig w/spool gun
    SMITHY 1324 mill/lathe
    60 gal. 7.5 hp air compressor
    Keep us posted on it, my son is going to build one for his mud truck. Do you have one of Jody's TIG fingers. Aluminum can get warm.
    I'm sure you know this but I will say it anyway. Make sure you check it for leaks with low pressure air and some soap suds. It is very easy for an aluminum weld to be porous. Especially if it is not extremely clean. I would check it with only a couple pounds of air pressure or you will buckle the sides.
    Many years ago I had a guy that wanted an alum. fuel tank for a plane modified. It was old and had sat open for several years. There was no flammable gases in it so I modified it for him. I did it as a favor to a mutual friend of ours. since I did it for free I did not go to any lengths to check it for leaks but I told him how to check it and insisted he be sure to check it before installing it. About 2 month later I get a call from my friend saying the guy installed it in the wing and skinned the wing, painted the plane and was reedy to test the pane. When he put fuel in the tank it leaked. He then wanted me to test it and reweld it. I refused to do anything more with it for 2 reasons. First was that the guy was told what to do but did not do it. 2nd he had put fuel in it and it was going to take time to get it ready to reweld. I was not willing to do all this for free to a guy that was too lazy to do what he was told needed to be done. I will never do anything again that I do not check myself weather I am being paid or not. The moral to this story is, never do any project for free . The mutual friend was an air frame mechanic and I suspect he had many larger problems with this guys plane since he was not doing the work but just inspecting it for this guy as a favor . I was glad I was not him.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    Quote Originally Posted by dzljon View Post
    Are you building to an off the shelf bladder or having one custom made?
    I do have a tig finger, love it!
    LONGEVITY 250EX Tig
    Thank you for sharing your experience, leak test is on the list already
    LONGEVITY 250EX Tig
ID:	12950small fuel cell i welded a few years ago.
    250 ex
    205 mig
    milwaukee grinder
    140e mig
  1. CGCINC Project#3: 1000lb. water fountain Many, Many pics
    By CGCINC in forum Personal Projects (no welder required)
    Last Post: 05-09-2012, 05:22 AM
  2. Finished my first Tig Project with pics
    Last Post: 04-15-2012, 03:35 PM
  3. Project 2 from Injected65. Fuel System Upgrade
    By Injected65 in forum On Road Fabrication
    Last Post: 03-26-2012, 08:35 PM
  4. CGCINC Project #1 Welding table ... Lots of PICS!
    Last Post: 12-25-2011, 10:36 PM
  5. Jr. Dragster Fuel Cell Project 1
    By TD2593 in forum Other Custom Fabrications
    Last Post: 12-16-2011, 07:28 PM
