Results 1 to 3 of 3
Thread: 325ext
  1. Default 325ext
    Will opening the case of my welder void the warranty?
    Quote Originally Posted by stevenopolis View Post
    Not usually. However, you might want to give tech support a call to get the proper procedure. Some models have a counter intuitive way of coming apart. Are you having a problem with the machine?
    Inconsistent arc starts. It will work fine, then nothing, then it works fine. It's just odd. I think I need to replace the ground or tighten everything up and dielectric grease the ground stuff. Been tied up working on a tamrock drill and haven't looked at the welder in a few days.
  1. Does Anyone Know? 325EXT
    By SteveY in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-08-2019, 05:12 AM
  2. 325EXT took a dump
    By WhitsonMetal in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 07-23-2015, 12:39 AM
  3. first tig purchase 325ext
    By duncan in forum Introduce Yourself
    Last Post: 01-12-2015, 04:56 AM
  4. New 325EXT Issue
    By kumaichi in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-09-2014, 10:05 PM
