Results 1 to 4 of 4
Thread: Settings guide?
    Default Settings guide?
    Does the Power I-Mig have a chart inside the door showing suggested amp and wire feed settings? I couldn't tell from the literature.
    No, they don't. These units have variable adjustment capability and not a set A,B,C, or D setting. Fixed settings lend themselves more to a chart situation. Also with the addition of arc force control, a third factor in setup, it makes it even more difficult to get a setting that works for everybody.
    These will get you in the ballpark, but there are so many variables that you really do need to fine tune for your application. A small adjustment can really make the difference between good enough for who it's for, and oh wow, that's nailed it.
    http://www.millerwelds.com/resources/calculators/
    If it's helpful, there are "Intro to MIG" videos from Jody Collier, here:
    http://welding-tv.com/category/mig-welding/
    Welding-tv is a sister site for WeldingTipsAndTricks.com.
  1. Electrode Guide?
    By Columbo in forum Stick Welding (SMAW)
    Last Post: 03-21-2013, 11:20 PM
  2. Will this roller guide fit?
    By Buggy Chief in forum Everlast Plasma Cutters (PAC)
    Last Post: 04-10-2012, 04:52 PM
  3. PP256 Setup Guide
    By posixPilot in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 12-16-2011, 02:40 PM
  4. NEW A81 Trafimet Wheel Guide
    Last Post: 07-05-2011, 04:30 PM
  5. Plasma Cutter Guide
    Last Post: 04-25-2011, 11:38 PM
