Hello All,
I'm about set on picking up an Everlast TIG and a cooler. I'm deliberating between the 250EX and the 255EXT. The price points of the two are close enough, so it really comes down to usability and reliability.
This machine would see about 95% aluminum work on 240V supply and 5% SS. We do a lot of 6010 in the 1/8" range and a fair amount of sheet work in 5XXX and 3XXX from .063 to .100".
Obviously the 255 has all the digital waveform options. The guy that would be running this machine most of the time is currently driving a dynasty which he loves...from what I can tell though he never changes a setting on the machine so it may as well be a syncrowave. He leaves the amps maxed out on the unit and runs it old school from the pedal with few exceptions. That being said...can any of you that actually have one of these comment on whether or not you use these features? Are there any appreciable productivity gains?
Knowing that he prefers to run everything from the pedal side should I opt for an upgraded pedal from the get go?
I also noticed that the 250 specifies an Infineon IGBT module, but the 255 just says IGBT module. Perhaps one of the Everlast reps can address the pro/con of this.
Thanks,
John
